https://www.luthiersforum.com/forum/
question about "Martin style" truss rod
https://www.luthiersforum.com/forum/viewtopic.php?f=10101&t=42128
Author:  Jdsupertinter [ Sat Dec 07, 2013 7:59 am ]
Post subject:  question about "Martin style" truss rod
ok, new to forum, have a potenial dumb question...... I've built two guitars, first two I just did reinforced necks, no adjustments, just a steel rod. On the third I ordered a Martin style truss rod that is 14 inches, but seems too short, it's suppose to be adjusable from soundhole, but then it's well short of the headstock, like the last 4 inches of my channel will be empty Is this ok? Or do I need to order a longer truss? Thanks for any input!! JD
Author:  bluescreek [ Sat Dec 07, 2013 8:56 am ]
Post subject:  Re: question about "Martin style" truss rod
yes it is adjusted from the sound hole but the rod is only about 1/2 in from the neck block. you have about 3 in from the sound hole to the barrel nut on the rod
Author:  Jdsupertinter [ Mon Dec 09, 2013 7:03 pm ]
yep, that makes more sense, thanks!!
