It is currently Wed Aug 20, 2025 9:35 am
PostPosted: Fri Nov 29, 2013 9:26 am
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Zip/Postal Code: 64081
has anyone used this product for french polishing?? way cheaper than the alcohol from hd and everclear is made from grain and is 95% clear?? and abt 15 $ for a bottle at the liquor store .
PostPosted: Fri Nov 29, 2013 10:56 am
I use it but mine states 99% pure. It flashes off slower than ethanol but the difference is very minor. In fact I filled two very small bottle caps with each type of alcohol to see which evaporated the fastest. A day later the ethanol won but by a very small margin.
PostPosted: Fri Nov 29, 2013 11:10 am
First name: Eric
Last Name: Reid
City: Ben Lomond
Zip/Postal Code: 95005
I use the 91% for cleaning shellac off my hands. I'm using 95% ethanol denatured with7% acetone. The one time I tried 99% isopropyl for French polishing, the finish took much longer to become serviceably hard. If you're patient, and give it enough dry time between sessions, it should work--it does for Michael.
PostPosted: Fri Nov 29, 2013 11:26 am
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Well I just paid 17.50 at the liquor store for some everclear . But I do have the regular 70% isopropyl that I can use as a cleaner. I was watching a youtube video that says the store bought HD /lowes alcohol has too many nasty additives,. I am using disposable gloves. I see all the pros using everclear, . I/m not patient , so will pass on the 91 %. When you say ethanol 95% are you talking abt, the stuff from the gas station ?? or is it a different type of grain alcohol from the liquor store variety. If so, where does one get 95 % ethanol ??Just wondering Thanks for the explanation.
PostPosted: Fri Nov 29, 2013 1:27 pm
isopropyl alcohol is not good for french polish you will see that it has more water in it . If you want to do french polish everclear is the best.
PostPosted: Fri Nov 29, 2013 2:09 pm
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Thanks john for the info that/s what I figured. I/m just finishing off a sample WRC board using lowe/s alcohol/dewaxed garnet ,man is this is ever time consuming(FP) for an impatient guy like me. Got another sample of walnut pore filled board . I/m trying to perfect my varnishing technique using thinned down behlens rock hard varnish for Cl gtrs.
PostPosted: Fri Nov 29, 2013 5:38 pm
First name: Eric
Last Name: Reid
City: Ben Lomond
No, not the gas station. If they sell the 190 proof Everclear where you live, and you can afford it, stick with that. They don't sell it in California, so I use SDA 23A. SDA stands for "Special Denatured Alcohol". and it just means that the recipe is enforced by the feds. SDA 23A is designed for use as a shellac solvent. It contains ethanol (Everclear), about 7% acetone, and less than 5% water. You can also buy 200 proof SDA 23A, but that flashes off a little too fast for my liking. Unless you jump through some licensing hoops, you can only buy 5 gallons per year of SDA alcohol. Five gallons will get you through a lot of guitars. I pay a little under 20$ per gallon--so it's a good bit cheaper than Everclear. The Chemisphere Corp. in St. Louis carries it. There must be someplace in K.C. that does. Pick it up yourself, or the shipping will cost more than the alcohol.
PostPosted: Fri Nov 29, 2013 9:20 pm
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Eric thank you very much for the deatailed explanation. My production rate is low right now .Soon to pick up.I appreciate the your explanation.It was the terminology that through me off. In kansas /iowa they have ethanol plants , hence the gas station reference lol. Back to sanding now. I feel I am slowly getting the hang of FP . I ordered three grades of shellac ,the dewaxed versions can be used under varnish , and the buttonlac with wax can be used a final coat for FP. I highly recommend the shellac shack, there prices are reasonable , and they ship priority post which me being impatient helps. Speak with malcolm, he is vy knowledgeable ,and helpful for newbies to shellac .Located in s. coast of oregon
These users thanked the author ernie for the post: nyazzip (Fri Nov 29, 2013 10:49 pm)
PostPosted: Sat Nov 30, 2013 3:49 am
Last Name: Curtis
City: Mangrove Mountain
State: N.S.W
Zip/Postal Code: 2250
Filippo Morelli wrote:
Our local whiskey distillery produces some real serious alcohol as a side effect of creating the whiskey. They can't sell it, but use it to disinfect things at the distillery ... and well, they can hand out a jar for noble activities like french polishing. It's organic, too :-D
Filippo
Sounds almost good enough to drink Filipo.
PostPosted: Sat Nov 30, 2013 10:17 pm
Last Name: Shanklin
City: Windsor
State: ON
Isopropyl alcohol only contains 70% ethanol. It is also called rubbing alcohol, but not for rubbing shellac.
Bob
PostPosted: Sun Dec 01, 2013 2:03 am
Last Name: Shaw
City: Philadelphia
State: PA
Zip/Postal Code: 19125
I know that some isoproyl alcohols that you buy at drug stores or wherever can have additives too. They add some stuff to make it bitter to deter drinking it.
Another day, another dollar.
PostPosted: Sun Dec 01, 2013 6:12 am
Bob
Isopropyl alcohol shouldn't contain any Ethanol. They are two different types of alcohol with slightly different chemical chains. For French Polishing you just need Isopropyl with a very high alcohol content. That's no different than the high content of something like Everclear. If you water it down it becomes less suitable for our use, it doesn't matter if that is Everclear or Isopropyl.
Rubbing alcohol is usually Isopropyl alcohol that has been diluted. So commonly available Isopropyl or 'rubbing alcohol' is unsuitable for French polishing. High per centage Isopropyl can be used for French Polishing though.
