It is currently Wed Aug 20, 2025 4:46 pm
PostPosted: Mon Nov 25, 2013 10:06 am
Here is the latest Luthier Tips du Jour video -The topic is hide glue.
This video as well as all my other videos are available via my website http://www.obrienguitars.com/videos/, LMI's website or on Youtube.
Enjoy!
These users thanked the author Robbie O'Brien for the post: Ebony (Sun Dec 01, 2013 10:33 am)
PostPosted: Mon Nov 25, 2013 1:04 pm
First name: Fred
Last Name: Tellier
City: Windsor
Zip/Postal Code: N8T2C6
Your usual fine job Robbie, great video
Fred
Fred Tellier
PostPosted: Mon Nov 25, 2013 1:08 pm
First name: Hilko
Last Name: Nackaerts
Country: Belgium
Yups, again great video!
FB Page
PostPosted: Mon Nov 25, 2013 9:45 pm
Thank you. Glad you guys are enjoying the videos.
PostPosted: Tue Nov 26, 2013 12:57 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
LMI should start carrying fish glue... it's not a replacement for hide but it's great for long open time applications like rims, kerfed lining, and bindings.
Typhoon Guitars
PostPosted: Thu Nov 28, 2013 9:02 am
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Zip/Postal Code: 64081
+1 rob , lots of vy important info
PostPosted: Thu Nov 28, 2013 6:10 pm
Some time ago I conducted a little experiment with hide glue concerning temperature. I placed the container with my hide glue in a pot of boiling water. I kept it boiling for about an hour and the glue temperature reached 185-190 degrees. I then glued three different species of wood with it...spruce, cedar and birch. I allowed it to set overnight. Next day, all three joints held snd the wood did not separate along the joint. So I'm no longer concerned about overheating the glue.
Sent from my GT-P3113 using Tapatalk
Under Compensated Nut!
PostPosted: Fri Nov 29, 2013 3:00 am
You won't get catastrophic failure but according to some it does weaken the glue. You also have to bear in mind what it will do over a long period of time. You can definitely come across some pieces of old furniture where the glue is very crumbly. I don't know if that was just bad glue or good glue that was badly prepared.
PostPosted: Fri Nov 29, 2013 3:03 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I guess hide glue dries out over time and becomes brittle. Keeping that in mind it was really easy to disassemble instruments assembled with hide glue because you can simply use a palette knife to pry it open slowly. When titebond/PVA/Elmers are used, you need to heat the palette knife (that was how I disassembled an instrument that was improperly glued with white glue)
By the way where can I find those 350 gram strength hide? LMI only carries the 192 gram stuff. Also is it possible to buy fish glue in powders like hide glue?
Typhoon Guitars
PostPosted: Fri Nov 29, 2013 8:52 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
That company can't ship outside of the US due to "custom restrictions" or whatever that means... every other suppliers ships hide and fish glue outside of the US routinely.
Typhoon Guitars
PostPosted: Fri Nov 29, 2013 9:07 am
First name: Kevin
Last Name: Quine
City: Hudson
State: MA
Country: Usa
You don't need to clamp it?? That sounds nice. I've always been clamp constrained in my building. I might have to give it a try
PostPosted: Sat Nov 30, 2013 7:22 pm
First name: Gil
Last Name: Draper
City: Knoxville
State: Tennessee
Thanks Robbie.
So where are you guys getting your fish? Think I'll try that on the next build.
PostPosted: Sun Dec 01, 2013 9:18 am
I've become a big fan of fish glue recently but plan on getting set up with hide glue once I'm in my new shop. The quick set time is going to be very useful for many applications. The ice cube tray idea is spot on.
How long will it last in the freezer?
PostPosted: Sun Dec 01, 2013 10:33 am
Country: UK
Wow, you've converted me to using Hide Glue again. Thanks Robbie, that was a great video!
