It is currently Fri Aug 15, 2025 9:18 am
PostPosted: Fri Nov 22, 2013 10:46 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I noticed Bluecreek guitars sells a router that uses an air die grinder. Can anyone tell me if they're any good? I know Bluecreek is well respected but I've seen a lot of cheap air pencil grinders that are a lot cheaper on ebay or whatever, so just wondering if their stuff is a cut above the average?
The stuff looks attractive because of its small size and high RPM... now if I can just fit a circle guide to it to do rosettes...
I've been looking at pencil grinders in Taiwan but they only accept 3mm bits, not 1/8" bits, so they won't really work...
Typhoon Guitars
PostPosted: Sat Nov 23, 2013 3:58 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
Question is, are there circle jigs that works with this setup? I think it will be perfect for rosettes. I had a homemade Wells/Karol jig that seems to flex a little bit, enough to make inconsistent rosette channel... that is wider at the bottom than the top!
Typhoon Guitars
PostPosted: Sat Nov 23, 2013 7:41 am
I like mine and it works great for detail routing routing tasks and inlay. Don't have a circle jig for it but that's not a bad idea. I use a standard Wells-Karol with a lam trimmer.
PostPosted: Sat Nov 23, 2013 7:53 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
So how are the runout on those air pencil grinder? I read the cheap ones have terrible runout, like on the order of .030" or more. I know dremels are terrible because there is a lot of play at the spindle... and the Foredom style grinder I have works well, no runout that I can detect or any plays at all... it's just a shame that the RPM is so low...
Typhoon Guitars
PostPosted: Sat Nov 23, 2013 10:30 am
these are very low runout. They are commercial units and are designed to work with metal. If you modify this for a rosette cutter you need to make a new top and use 3 supports for higher accuracy. I also have a higher end unit that uses a Souix brand unit that spins at 70,000 rpm. The dremel is way too much runout , and the foredom is a good unit for those without Compressed air. Thanks for the kind words by the way
PostPosted: Sat Nov 23, 2013 10:39 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
Understood. I saw more expensive ones that uses higher quality bearings in Taiwan but it costs the same as your unit (but without any router base). So it looks like I will definitely be getting this one... I guess for rosette I can still use the laminate trimmer, visibility isn't so critical there but for inlays the lam trimmer seems too heavy especially for delicate work.
Typhoon Guitars
PostPosted: Sat Nov 23, 2013 11:23 am
John Hall's unit is excellent for inlay work.
PostPosted: Sat Nov 23, 2013 6:12 pm
Last Name: Tulloch
State: Vermont
Big fan of Blues Creek here !....I prefer the Sioux die grinder though....and it's worth the extra moohla, in my humble opinion. I use it for inlay work too..actually I should say I only use it for inlay. For Rosettes I use the Dremel 8220-2/28 12-Volt Max Cordless with the stewmac downcut bit....solved the cord twist problem, and the speed is fine for a good job.
Michael
PostPosted: Sat Nov 23, 2013 6:50 pm
State: Tennessee
This is a nice one: http://www.use-enco.com/1/1/45571-12r04 ... nders.html
PostPosted: Sun Nov 24, 2013 6:48 am
http://www.amazon.com/Pencil-Die-Grinde ... B0001X1YLA
these are the ones I use the most. it spins at 70,000 rpm and uses less air. It is also has a more cylindrical shape and affords itself to work in a machined hole.
http://www.amazon.com/Pencil-Grinder-PE ... pencil+die
PostPosted: Sun Nov 24, 2013 11:43 am
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Zip/Postal Code: 64081
I bought the john hall air die grinder and the stew- mac new circle cutter. I had a machinest reconfigure the circle cutter to cut a perfect circle using the die grinder .He found dead center by using a Large CNC machhine. So now it can be used either way with the stew mac base as a circle cutter or inlay cutter using the john hall air die grinder .
PostPosted: Mon Nov 25, 2013 1:42 am
Last Name: Sonksen
City: PORTLAND
State: Oregon
Zip/Postal Code: 97216-2013
bluescreek wrote:
http://www.amazon.com/Pencil-Die-Grinders-pencil-grinder/dp/B0001X1YLA
I just wanted to point out a huge pet peeve of mine which takes place on the page you linked. The one star review by someone who didn't realize this was a pneumatic tool and had no idea how to use it. Can't stand it when someone takes the time to write a poor review based on their own mistakes, like writing a bad review of a recipe after you change four of the ingredients. Just doesn't make sense!
PostPosted: Mon Nov 25, 2013 1:48 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
By the way is it possible to get metric collet for this thing? I realized in Taiwan they don't always have 1/8" bits.
Typhoon Guitars
PostPosted: Mon Nov 25, 2013 2:13 am
First name: Eric
Last Name: Reid
City: Ben Lomond
Zip/Postal Code: 95005
Just a note on runout and router bits. If your router (or Dremel, Foredom, die grinder) has runout, a straight flute bit will cut a scalloped channel. Multiple passes will even out the scallops.
An up-cut, or down-cut bit in a tool with runout will cut a fascinating assortment of channels--hourglass, barrel shaped, wedge, taper. You'll get a new profile every time you put the bit in.
I only mention this because I felt like an idiot when I finally figured it out.
PostPosted: Mon Nov 25, 2013 2:20 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
When you say scalloped, hourglass, barrel profile, do you mean top profile or vertical profile? I find when I cut a rosette channel I get absolutely no deviance with a single pass, but when making multiple passes to cut wider channel I run into problems like the bottom half of the rosette circle being wider than the top... but I think this has more to do with the circle jig flexing than runout. I never have any issue when cutting saddle slots for example because nothing flexes.
Typhoon Guitars
PostPosted: Mon Nov 25, 2013 6:33 am
the bits are available and the dremel tool has a collet for the smaller bits. I will see if one if available.
PostPosted: Mon Nov 25, 2013 6:40 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I have a few 3mm collets that looks Dremel type but I was wondering if they are interchangable...
Typhoon Guitars
PostPosted: Wed Jan 28, 2015 8:01 pm
First name: Charlton
Last Name: Wang
Hi John,
All the documentation I can find on this grinder seem to suggest a cfm requirement of 5.50. On your website you indicate 0.9cfm. Is your model actually the same or is it different? I have a pretty small compressor and it definitely can't pump out 5.5cfm.
Charlton
PostPosted: Wed Jan 28, 2015 8:05 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I can confirm it definitely requires 5CFM or more. It's surprising how much air this little bugger uses. If you have a small compressor get an electric die grinder and have someone make an acrylic router jig.
Typhoon Guitars
PostPosted: Wed Jan 28, 2015 8:20 pm
First name: Dan
State: Pennsylvania
Evening, all.
Question about runout with dremels:
Is there any way to mitigate this? Would buying higher quality bits aid in reducing wobble or is this how it is always going to be with that tool?
PostPosted: Wed Jan 28, 2015 9:03 pm
I have John's lower cost version. It runs great on my portable 4.4CFM @ 90PSI Ingersoll Rand compressor.
PostPosted: Wed Jan 28, 2015 9:10 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I heard about putting heat shrink tube around the bearing to improve its runout...
Typhoon Guitars
PostPosted: Thu Jan 29, 2015 9:15 pm
Last Name: Wang
Thanks, Tai Fu. That's too bad. I guess the slower grinder has much more modest air requirements. Maybe I'll get that instead.
Charlton
PostPosted: Fri Jan 30, 2015 9:03 am
I see that they did change the air requirement . The souix uses less air. I will change the listing thanks
As for run out , these have very little as compared dremel tools. The die grinder uses a roller bearing and not a bushing.
PostPosted: Fri Jan 30, 2015 9:31 am
Last Name: Wang
I thought the 70k one in the link was the Sioux. It's the one that presumably needs 5.5cfm.
Charlton
Users browsing this forum: Terence Kennedy and 13 guests
