It is currently Wed Aug 20, 2025 8:21 pm
PostPosted: Mon Nov 11, 2013 2:27 pm
Last Name: Moore
City: Nacogdoches
State: Tx
Zip/Postal Code: 75965
I was just starting to check my scale length so that I could figure compensation and bridge placement. The scale is 25.4" - I got the fretboard from LMI as well as the Martin style bridge.
My actual distance to the first fret is 1 27/64th, and the plans (same scale length) show 1 26/64th.
Is this enough error to worry about? The rest of the frets are correct. I just failed to cut off enough at the nut end. Now that the fretboard is on the neck, I can't take it to the disk sander and scrub it away. If I do need to take some off, any suggestions on doing that with ebony? I have some files, sandpaper, but not much else.
Thanks for any help,
Bob
Bob
From the oldest town in Texas.
PostPosted: Mon Nov 11, 2013 3:37 pm
Stewmac fret calculator shows 1 inch and 27.23/64ths from nut to 1st fret for 25.4 inch scale.
Maybe the plans build in some nut compensation?
Or the plans could be for a martin 25.34" scale (often referred to as 25.4)
That would be 1 27/64"
Anyway, someone may pipe up with cents error for 1/64" difference.
If you want to remove the excess. a sharp chisel vertically down to the neck wood is the way I would remove it.
PostPosted: Mon Nov 11, 2013 3:50 pm
Last Name: Moore
City: Nacogdoches
State: Tx
OK, maybe I should just leave things alone. On a little closer inspection, my difference is less than the 1/64. Poor ole eyes can't get any closer even with glasses and magnifying lenses added.
Thanks for your input Colin.
Bob
PostPosted: Mon Nov 11, 2013 4:14 pm
Do the plans actually state that measurement?
The plans themselves may not absolutely accurate as they can also expand and contract.
PostPosted: Mon Nov 11, 2013 5:37 pm
Last Name: Moore
City: Nacogdoches
State: Tx
Excellent point. I've got some other accurate scale measurements, especially Colin's, and I am very close to those, so I'm going to let this one go to sleep.
Thanks for all the help, everyone.
Bob
PostPosted: Mon Nov 11, 2013 6:05 pm
That went completely past me.
It didnt occour that anyone would measure fret placement from a printed plan...... duh
Ctrl/Alt/Del... [Reset]/[mindset]/[Reboot]...
PostPosted: Mon Nov 11, 2013 7:49 pm
I have never seen a set of prints that would allow a person to measure directly off of them . Most include a table with the proper measurements for fret spacings.
PostPosted: Tue Nov 12, 2013 4:57 am
First name: Tom
Last Name: West
State: Nova Scotia
Bob: Since you say that all the distances are correct to the drawing except for the first fret to nut, I suggest that who ever did the drawing shortened the first fret to nut to help with intonation especially in the first position.
Tom
PostPosted: Tue Nov 12, 2013 1:49 pm
First name: Kevin
Last Name: Quine
City: Hudson
State: MA
Country: Usa
Not all 25.4" scale lengths are the same. LMI knows what they're doing so I'd leave it alone. I've used their fretboards before and never had a problem
PostPosted: Tue Nov 12, 2013 3:25 pm
First name: Murray
Last Name: MacLeod
City: Edinburgh
Country: UK
maybe a tad cryptic ...?
PostPosted: Tue Nov 12, 2013 3:30 pm
First name: duh
Last Name: Padma
1/64 of an inch eh...best just chain saw it off and be done with it. laughing6-hehe
PostPosted: Tue Nov 12, 2013 3:58 pm
First name: Greg
Last Name: B
City: Los Angeles
Try a file with an edge ground flush, or sandpaper glued to a stick. Agreed that it sounds like the plans included a small amount of nut compensation, which will help the first frets play in better tune. It wouldn't hurt to take off that 1/64th, but zillions have guitars have been built without nut comp.
I've gotten best intonation with LMI cut fingerboards by taking 20-30thou off the ends. Nothing wrong with them, they just don't pre-cut them with nut compensation (thank goodness).
PostPosted: Tue Nov 12, 2013 7:56 pm
First name: Tom
Last Name: West
State: Nova Scotia
Greg: There is a bit of built in compensation..........................1/2 the fret slot...!! Or at least on the pre-slotted ones I have received from LMI. There is a fret slot at the nut position. Agreed there should be a bit more.
Tom
PostPosted: Tue Nov 12, 2013 8:44 pm
First name: Greg
Last Name: B
City: Los Angeles
Yeah, that is true, 1/2 a kerf slot! The first guitar I made with an LMI slotted board I just left it as is, but eventually went back later to dial it in with a digital tuner. In practice it seems it takes a touch more than .011" to get things perfect - or at least pretty good.
Users browsing this forum: DennisK and 29 guests
