It is currently Wed Aug 20, 2025 8:30 pm
 Post subject: Homemade Binding
PostPosted: Tue Sep 10, 2013 3:02 pm
First name: Aaron
Last Name: Thompson
City: Atlanta
State: Ga
Zip/Postal Code: 30308
Thinking about making some binding with laminates that form a cool shape. Maybe something like herringbone.
Anyway, my question is - when I go to bend it, won't the glue just soften and deform the pattern? How do people do this?
Thanks.
"I'm not going to say that perfection has never been achieved. However, if it has, it probably went unnoticed due to it's lack of character."
 Post subject: Re: Homemade Binding
PostPosted: Tue Sep 10, 2013 3:55 pm
First name: Tom
Last Name: West
State: Nova Scotia
Aaron: Have never seen herringbone used as binding but I use it quite often as a top purfling. A run under hot water and then bend around a form, hold in place with brads and use a thin backer strip to prevent the brads from marking the bone. I also keep a hair dryer at the ready in case a bit of extra heat is needed. Let it dry in place. It will tend to relax when it comes of the form but works easily when your doing your binding. As to your original question, I have not had a problem with it coming apart or distorting the pattern.
Tom
PostPosted: Tue Sep 10, 2013 4:07 pm
First name: Aaron
Last Name: Thompson
City: Atlanta
State: Ga
Forget I said Herringbone. I just mean something similar. Kinda like a pattern of tiny veneer strips of different woods cut and arranged in a pattern and a long piece on either side to hold it all together. Seems like this would get all messed up once the wood gets hot enough to bend. Am I wrong? Maybe it is purfling that I'm thinking of. I feel like I've seen this done on Rosettes though and that's a full circle.
PostPosted: Tue Sep 10, 2013 5:15 pm
First name: Tom
Last Name: West
State: Nova Scotia
Aaron: Are you saying side purfling under the binding strip. I have only seen solid lines used there.
Tom
PostPosted: Tue Sep 10, 2013 5:51 pm
First name: Aaron
Last Name: Thompson
City: Atlanta
State: Ga
Tom
I guess I was thinking about purfling which doesn't get bent with such a tight radius if at all. I was just observing my dad's old guitar and noticed a cool pattern on it. But you're right... It was purfling strips on the back.
When you do a multiple layer binding, do you install the pieces separately or pre-laminate them?
PostPosted: Tue Sep 10, 2013 6:47 pm
First name: Tom
Last Name: West
State: Nova Scotia
Aaron: I glue purfling to the binding before bending using yellow glue. Then the strips are taped so the purfling are back to back. Masking tape every 4"or 5" and then bend with a heating blanket on a bending form. Have had no trouble with the bond.
Tom
PostPosted: Tue Sep 10, 2013 7:02 pm
Hey Aaron, I suggest doing a search for radial purfling. That's what I think you're referring to.
PostPosted: Tue Sep 10, 2013 7:14 pm
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
Do you mean something like this?
Brian
PostPosted: Wed Sep 11, 2013 12:40 pm
First name: Kevin
Last Name: Quine
City: Hudson
State: MA
Country: Usa
For fine pattern purfling like herringbone I just heat it with a cloths iron on the bench and bend it into the channel.
For something like rope binding or Brian's photo above....I glue on a veneer to the outside so it holds together while bending. Then the outside veneer gets scrapped off
These users thanked the author Quine for the post: absrec (Thu Sep 12, 2013 1:14 pm)
PostPosted: Thu Sep 12, 2013 1:20 pm
First name: Aaron
Last Name: Thompson
City: Atlanta
State: Ga
That's a great idea! I knew it must be something like that. Just couldn't quite put my finger on it.
Users browsing this forum: No registered users and 41 guests
