https://www.luthiersforum.com/forum/
End graft before sides
https://www.luthiersforum.com/forum/viewtopic.php?f=10101&t=41298
Author:  jlneng [ Mon Sep 02, 2013 10:21 pm ]
Post subject:  End graft before sides
Hello,
After seeing multiple posts regarding problems with purfing at end graft, I was curious if any one glues the end graft to the end block before gluing the sides? I have done this on my last 2 flamencos and it worked great. Even though I am using a spanish heel for the neck/top/sides, I would expect this would work for SS construction as well. The only caveat is the bottom end of the sides must be cut fair and square.
Author:  DennisK [ Tue Sep 03, 2013 12:44 am ]
Post subject:  Re: End graft before sides
If it works, do it.
I've tried several times to get a clean seam that doesn't need a graft, and so far haven't succeeded. Trying to get a perfect joint against a pre-glued graft wouldn't be any easier. A knife and chisel is the easiest for me, so that's what I use :)
Author:  Tom West [ Tue Sep 03, 2013 10:46 am ]
I think guitar building is tough enough doing it the conventional way..........no need to complicate things...............BUT, if you find this works for you, who can argue with that fact. If it works and looks good no body is going to quibble about how you did the construction.....!!! Go for it...!
Tom
Author:  Tai Fu [ Tue Sep 03, 2013 1:08 pm ]
I don't know how, but I actually managed to get a clean seam that would not require a graft on my jumbo build. I will still put a graft there but this is not something I was able to do before. All I did was mark the part, and trim it with a small backsaw and glued the block in. The seams are actually off center however because I couldn't find the center of the form... something to do with the pieces I use to keep it together. I will be able to correct it when putting the graft in.
Author:  jlneng [ Tue Sep 03, 2013 1:51 pm ]
FYI:
To get the end of the ribs perfectly square, I touch them up against a disc sander to give me a nice flat and straight edge to butt up against the end graft. Different strokes....
Author:  Bryan Bear [ Wed Sep 04, 2013 4:31 pm ]
jlneng wrote:
FYI:
Thanks John, I was about to suggest you show us how you do it. For me, the difficulty would be matching them up while using an outside mold. Building on a solera there would be a little more leeway on exactly how wide the lower bout is. Inside the mold, your width is the limiting factor. Too bad to, this thread has me thinking it would be cool to joint the ends of the sides like you do the top seam and have no graft; I just don't have the skill/precision to pull it off. If I'm being honest, I do a sloppy job here because I know I have the end graft to cover my butt. . .
