It is currently Fri Aug 22, 2025 3:13 am
PostPosted: Tue Sep 03, 2013 9:27 pm
Last Name: Livermore
State: Minnesota
This guitar barks like a mad dog, but in an angelic songlike sort of way.
The client wanted a guitar that sounded "as good as" my daily go-to classical.
I promised him that if I had known what I know when I built the first one, it would sound even better.
And I followed through.
Big, deep bass. Balanced, rich trebles. Throaty top end, all the way to the high b.
Every detail came from the Brune' plan (except the sideport, which I believe to be an upgrade from the original). The rosette was purchased from David Schramm. The rest was made in my shop.
All binding, purfling and the headstock inlay were made from scratch.
The top is Engelmann Spruce, Back and sides are EIR, neck is Spanish Cedar.
Here are a few photos
Hope you enjoy,
PostPosted: Tue Sep 03, 2013 10:29 pm
First name: Rob
Last Name: McDougall
City: Cochrane
State: Alberta
Looks great, cool headstock inlay!
Still trying to get my head around:
"barks like a mad dog, but in an angelic songlike sort of way" ....
I am going to keep that in mind as a design goal when I build my next one... :-)
PostPosted: Tue Sep 03, 2013 11:12 pm
Congratulations Dave! Sounds like it came out great, way to go.
PostPosted: Wed Sep 04, 2013 12:03 am
First name: Tony
Last Name: C
City: Brooklyn
She's a beauty. Can we hear her bark in her angelic sort of way?
http://www.CostaGuitars.com
PMoMC
PostPosted: Wed Sep 04, 2013 7:56 am
Very Nice! Congratulations.
http://www.booneguitars.com
https://www.facebook.com/pages/Stephen-Boone-guitar-builder/488208541257210
PostPosted: Wed Sep 04, 2013 8:22 am
Last Name: Parchem
City: Seattle
State: Wa
Zip/Postal Code: 98177
Great looking guitar!
PostPosted: Wed Sep 04, 2013 9:45 am
Outstanding, Dave. Fine job on that one! [clap] [clap] [clap]
PostPosted: Wed Sep 04, 2013 10:16 am
First name: Beth
Last Name: Mayer
City: Tucson
State: AZ
Really fabulous, Dave! Congratulations. I'd like to hear her bark too :)
PostPosted: Wed Sep 04, 2013 11:43 am
State: Minnesota
Thanks for the kind words.
I will see what I can do about a sound clip, but the client already has it!
PostPosted: Wed Sep 04, 2013 2:23 pm
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Zip/Postal Code: 64081
Well done an bravo
PostPosted: Wed Sep 04, 2013 4:02 pm
Last Name: Imbler
State: KS
Zip/Postal Code: 67204
Dave, I have a couple of questions as I build that type of guitar as well.
1) Did you use Brune's soundboard thickness dimensions or go closer to David Schramm"s recommendation of .090 for Englemann.
2) What is your string height at the bridge saddle? It looks like a lot of saddle exposed over the bridge, but that might be an illusion,
thanks, Mike
PostPosted: Wed Sep 04, 2013 4:13 pm
State: Minnesota
The top thickness was pretty thin as I recall. I dimension it quite intuitively with my drum sander and tend to stop when it feels about right.
I stopped a little later than I wanted to on this one. Right after the cross grain stiffness started to get a little flimsier than I like. But it rang like it should have and I went with it.
The saddle height is right at 12mm above the top.
DL
PostPosted: Wed Sep 04, 2013 4:56 pm
Last Name: Imbler
State: KS
Thanks Dave - I wind up at about 12 mm as well, with a fairly thin top. Hauser must have had a really floppy
piece of spruce to wind up at his thickness. I suspect that is why many report that following the plan doesn't give them good results - too stiff,
PostPosted: Wed Sep 04, 2013 10:43 pm
First name: Bruno
Last Name: Piancatelli
Country: Argentina
I Haven´t seen the plan but I´ve read about that guitar and it seems that it might take a low density spruce with light bracing and little doming to be able to get away with the thick top.
And spruce can vary a lot in density. right now im building one with a light Italian spruce (.345 grams) and ended up at 2,6mm central area and 2,4mm on the periphery. Even at that thicknes the bare plate was already very light, 115grams. and im using a rather big plantilla.
I think the plan should include some information about the caracteristics of the original soundboard. Thats If it was possible to obtain that data from a finished instrument.
These users thanked the author munen for the post: Imbler (Thu Sep 05, 2013 1:29 pm)
PostPosted: Thu Sep 05, 2013 9:34 am
Outstanding!
