It is currently Tue Jul 22, 2025 1:18 am
 Post subject: Bridge Pin Taper
PostPosted: Tue Sep 04, 2012 11:38 pm
First name: Phil
Last Name: Hartline
City: Warrior
State: Alabama
I know this was discussed in a recent thread, but I am still confused. I know I need a tapered hole for my bridge pins, but what angle do I need?
Last year, I bought a Stew Mac Standard reamer, which according to their web site, has an angle of 2 degrees. This one works for violin tuning pegs and end pins. I noticed they also have two reamers for bridge pins, one at 3 degrees and one at 5 degrees.
I would prefer to have things match perfectly, but what angle reamer do I need? Is one taper more common than the other? Any help much appreciated!
Phil
http://www.oleninstruments.com
"Those who tilt at windmills are only considered insane by those who can't see the dragon."
 Post subject: Re: Bridge Pin Taper
PostPosted: Wed Sep 05, 2012 1:10 pm
First name: Darryl
Last Name: Young
State: AR
IIRC, Martin uses a 5 deg taper. Sometimes the ball end on the end of the string has a tight fit using this taper so some custom builders use a 3 deg taper (maybe not the only reason). So I think the 5 deg is more common likely because it was the Martin standard.
Hopefully I don't have the two tapers reversed <smile>.
PostPosted: Wed Sep 05, 2012 3:54 pm
First name: Phil
Last Name: Hartline
City: Warrior
State: Alabama
Thanks, that's what I needed to know.
Phil
Users browsing this forum: Michaeldc and 24 guests
