It is currently Fri Aug 01, 2025 11:41 am
PostPosted: Thu Aug 30, 2012 10:44 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I will be getting this job from someone who attempted to remove a bridge himself, and botched it....
He basically tore a lot of wood fiber from the top removing the bridge, and I was wondering, if the surface under the bridge is uneven what would be the right thing to do to even them back out? Should I inlay more spruce into that space (a difficult job) or smooth it out the best I can and glue it back on?
Typhoon Guitars
PostPosted: Thu Aug 30, 2012 10:52 am
Country: Romania
It's insane how much lacquer the factory left in there!!
The tearout looks minimal, just clean around it as well as you can. Don't try to blend / soften it as this will only increase the thick glue area.
The important part is towards the back edge, that is where you want good contact between fresh wood on both surfaces.
Build log
PostPosted: Thu Aug 30, 2012 11:25 am
^^^ What he said. ^^^
PostPosted: Thu Aug 30, 2012 11:34 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
upon further examination it looked as though its one of those cheap guitar where they stick the bridge onto the still wet finish or something, and those glue doesn't release with heat but doesn't hold on so well... I really hate those.
Typhoon Guitars
PostPosted: Thu Aug 30, 2012 12:31 pm
No, you can see the area where the finish was removed from the top before gluing the bridge, and they left some fairly large areas of finish under the bridge. It looks like some of the spruce that came off the top with the bridge has been scraped away from the bottom of the bridge. I would remove more finish from the top so that the bridge completely seats on bare wood. This will reduce that amount of non-contact with the joint. Glue with HHG and you should be good to go.
PostPosted: Thu Aug 30, 2012 1:38 pm
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Zip/Postal Code: 64081
Like barry says HHG.I would leave as many of the spruce bits on to get a good tight fit
PostPosted: Thu Aug 30, 2012 9:35 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I usually like to sand the bottom of the bridge to make sure the surface is clean, how do I leave the spruce bits on in order to do that? HHG doesn't stick too well to dirty wood.
Typhoon Guitars
PostPosted: Thu Aug 30, 2012 10:55 pm
Tai - in all my years of regluing popped bridges, I can tell you that there isn't enough wood gone to make a difference. Sand or scrape the bridge clean, and remove the excess finish from the top with a scraper or exacto blade (sanding there is kind of a pain). Glue that baby up, and clamp it.
I promise you'll be good to go.
PostPosted: Thu Aug 30, 2012 11:27 pm
First name: Nils
Last Name: Johnson
City: Boston
State: Massachusetts
I would...1.) Pull large splinters of spruce off the bridge, and glue them back to the top. 2.) Place bridge on guitar and score around the edge. 3.) Remove excess finish to score line with chisel. 4.) Level top as much as is within reason using a small sanding block. (its okay to overlook relatively small voids) 5.) Glue bridge (after having sanded flat again) to guitar.
PostPosted: Fri Aug 31, 2012 4:53 am
That's basically how I would do an expensive Guitar bridge. Dissolving the original glue that is on the bridge and pulling off splinters. Re-glue them to the corresponding area. I tend to gently scrape the gluing areas rather than sand.
On a cheap Guitar I wouldn't bother pulling off splinters . . .
PostPosted: Fri Aug 31, 2012 4:55 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I always scrape that area... I can't achieve pinpoint accuracy with sandpaper... its just not possible for me. With a scraper you can accurately clean a small area but with sandpaper its like painting with a big brush.
Typhoon Guitars
PostPosted: Fri Aug 31, 2012 8:02 am
I would first make sure that the bridge is in the proper place to begin with. A lot of those cheap guitars are intonated badly. Then clamp the bridge down and score a line around it with a sharp razor point. I never felt comfortable using a router on the top though it's probably the quickest and easiest. Either way the scored line will flake the poly finish off at the right spot. I use a chisel and lift it off and then scrape it clean.
Users browsing this forum: Bing [Bot] and 34 guests
