Official Luthiers Forum! https://www.luthiersforum.com/forum/ |
SPLIT FINGERBOARD " Update " Saved IT !! https://www.luthiersforum.com/forum/viewtopic.php?f=10101&t=33194 |
Page 1 of 2 |
Author: | WudWerkr [ Fri Aug 12, 2011 3:26 pm ] |
Post subject: | SPLIT FINGERBOARD " Update " Saved IT !! |
I am so freekin chapped , where is my beer ! ![]() ![]() Started tapping in the frets on my fingerboard that has the purpleheart inlays and been sanded to a 320g and buffed to a nice shine . I got all the way to the last 3 and the board split lengthwise about half way down . ![]() ![]() ![]() ![]() ![]() ![]() |
Author: | StevenWheeler [ Fri Aug 12, 2011 3:48 pm ] |
Post subject: | Re: SPLIT %&&%%$$%^& FINGERBOARD |
I'll add that to my reasons not to do fingerboard inlays. You know, Jim, if you were working at 3:00pm on a Friday, this would never have happened. Steve |
Author: | WudWerkr [ Fri Aug 12, 2011 3:55 pm ] |
StevenWheeler wrote: I'll add that to my reasons not to do fingerboard inlays. You know, Jim, if you were working at 3:00pm on a Friday, this would never have happened. Steve ![]() ![]() ![]() ![]() So freekin irritating , I just went online and bought the fret caul to press frets . I have the press to use , guess I shoulda done this earlier . |
Author: | Mark Tripp [ Fri Aug 12, 2011 6:30 pm ] |
Split happens... ![]() Sorry Jim, couldn't resist... -Mark |
Author: | WudWerkr [ Fri Aug 12, 2011 7:33 pm ] |
Mark Tripp wrote: Split happens... ![]() Sorry Jim, couldn't resist... -Mark ![]() ![]() Thats a good one |
Author: | Lavrov Guitars [ Fri Aug 12, 2011 7:45 pm ] |
Man Jim, sounds like this is a rough build for you. ![]() But maaan, can anything else go wrong??? ![]() Sorry man, hopefully you can get it to work out. If it were me, lotsa LMI white glue, couple clamps, take the rest of the day off, and tomorrow, VOILA!!! |
Author: | alan stassforth [ Fri Aug 12, 2011 9:03 pm ] |
Bondo!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! |
Author: | thebolo [ Fri Aug 12, 2011 10:00 pm ] |
You can fix anything with bondo. The more things you break or mess up, the less things will break or get messed up on the next one. |
Author: | Mark Groza [ Sat Aug 13, 2011 7:45 am ] |
Todd Stock wrote: I wonder if fretting after the board is on the neck would have prevented that. My thoughts as well! |
Author: | WudWerkr [ Sat Aug 13, 2011 11:13 am ] |
Todd Stock wrote: I wonder if fretting after the board is on the neck would have prevented that. Maybe , but i was up over the body area when it split 3 frets from where the sound hole would be. Actually I think my mistake was I made the inlays to big They are about 090 thick and if you follow the wite line ive drawn on the pic you can see it split right down the inlay line . I weakened the board to much apparently Attachment: Fiboard.jpg
Author: | WudWerkr [ Sat Aug 13, 2011 11:18 am ] |
Lavrov Guitars wrote: Man Jim, sounds like this is a rough build for you. ![]() But maaan, can anything else go wrong??? ![]() Sorry man, hopefully you can get it to work out. If it were me, lotsa LMI white glue, couple clamps, take the rest of the day off, and tomorrow, VOILA!!! Actually I have 4 builds going . And YES anything else CAN go wrong !! ![]() |
Author: | WudWerkr [ Mon Aug 15, 2011 9:07 am ] |
Post subject: | Re: SPLIT FINGERBOARD " Update " Saved IT !! |
Was able to save my split fretboard ...... Kewl huh ![]() ![]() ![]() Attachment: redgreen.jpg Attachment: 100_1181.jpg Attachment: 100_1182.jpg Little buffing and new frets and she b jusss like new !!! |
Author: | meddlingfool [ Mon Aug 15, 2011 10:04 am ] |
Cool, Now instead of cumbersome artsy fartsy position markers, you can just label the frets with a sharpie! |
Author: | WudWerkr [ Mon Aug 15, 2011 10:06 am ] |
meddlingfool wrote: Cool, Now instead of cumbersome artsy fartsy position markers, you can just label the frets with a sharpie! ![]() ![]() |
Author: | Mark Tripp [ Mon Aug 15, 2011 10:20 am ] |
Nice! Kinda looks like the interior of my truck now... |
Author: | SteveSmith [ Mon Aug 15, 2011 7:35 pm ] |
The (Padma) would be proud ![]() Nice save! |
Author: | alan stassforth [ Mon Aug 15, 2011 9:05 pm ] |
When bondo doesn't work, duct tape!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Also fixes dings in surfboards! |
Author: | WudWerkr [ Fri Aug 19, 2011 1:45 pm ] |
Filippo Morelli wrote: So this will go against popular opinion for sure ... but Wud I don't see why you can't glue that puppy back together, then glue it down to the neck. The fretboard wood looks dark so I doubt you'd ever see the repair. With all the lateral surface area of the fretboard to the neck, I doubt it will go anywhere. I am actually going to try and save it . Will let you know how things go. |
Author: | CharlieT [ Fri Aug 19, 2011 2:13 pm ] |
WudWerkr wrote: I am actually going to try and save it . Will let you know how things go. Good luck, Wud. If the women don't find you handsome, they should at least find you handy. ![]() |
Author: | WudWerkr [ Fri Aug 19, 2011 2:22 pm ] |
CharlieT wrote: WudWerkr wrote: I am actually going to try and save it . Will let you know how things go. Good luck, Wud. If the women don't find you handsome, they should at least find you handy. ![]() Is there a third choice ?? ![]() ![]() |
Author: | SteveSmith [ Fri Aug 19, 2011 2:25 pm ] |
WudWerkr wrote: CharlieT wrote: WudWerkr wrote: I am actually going to try and save it . Will let you know how things go. Good luck, Wud. If the women don't find you handsome, they should at least find you handy. ![]() Is there a third choice ?? ![]() ![]() Are you rich?? ![]() |
Author: | CharlieT [ Fri Aug 19, 2011 2:29 pm ] |
SteveSmith wrote: Are you rich?? ![]() Right - I believe that is indeed the only other option. ![]() ![]() ![]() |
Author: | WudWerkr [ Fri Aug 19, 2011 2:46 pm ] |
Weeeeeeeeellllllllll Im Hosed then !!! ![]() |
Author: | Bryan Bear [ Fri Aug 19, 2011 2:56 pm ] |
WudWerkr wrote: Weeeeeeeeellllllllll Im Hosed then !!! ![]() If you rearrange that, you are back in business. Just say you are Weeeeeeeeellllllllll Hosed. |
Author: | CharlieT [ Fri Aug 19, 2011 3:18 pm ] |
Bryan Bear wrote: If you rearrange that, you are back in business. Just say you are Weeeeeeeeellllllllll Hosed. ![]() ![]() ![]() |
