It is currently Tue Aug 19, 2025 2:44 pm
Post new topic Reply to topic  [ 29 posts ]  Go to page Previous  1, 2
 Post subject: Re: Bracing question
PostPosted: Fri Feb 28, 2014 7:52 pm
Last Name: Russell
State: Michigan USA
I wish I could speak so eloquently.
Good to see you back around Hesh. [:Y:]
Cheers,
Bob
PostPosted: Fri Feb 28, 2014 8:02 pm
First name: Justin
Last Name: North
City: Chattanooga
Zip/Postal Code: 37416
Thanks Clay. The pre war bracing is what's on my D-18 Vintage Series, and to my ear it's the model of guitar that sounds like the dreadnought sound in my head. I've seen that Martin also scallops the braces in the vintage series OO's, and the OO template I got from Waldron Music shows scalloping as well. I'm always interested to see the bracing of other builders and compare it to what I've seen and read. Mike Baranik makes some really nice guitars, and I've seen a pic on his site where he's scalloped the right hand X brace and the tone bars, but only tapered the X brace on the left side. So it's a combination, which is cool. I wish I could do what Hesh suggested for Nick above, but I don't have the budget right now.
PostPosted: Fri Feb 28, 2014 10:56 pm
First name: Greg
Last Name: B
City: Los Angeles
JustinNorth wrote:
Greg,
Let's try and simplify the terminology a little. My understanding (and I could be wrong) is that the more material left on the brace the less flexible it is. The less flexible it is, the less the top moves. When you say that it is the stiffness of the brace that promotes treble, I agree, but all things being equal the more wood left on that brace the stiffer it will be. That being said, I'm not sure how this is "irrelevant". More wood = stiffer brace, right? That's what he meant by "mass".
Hey Justin, I think I see where the confusion is arising. By mass I mean mass in the formal sense - essentially weight. You are using the word mass in the colloquial sense, IOW bulk or volume. So if we substitute the word 'bulk' for 'mass' it should make sense to both of us.
Yes, if you leave more bulk of brace it will be stiffer, and the stiffness promotes treble. The stiffness is directly related to the bulk of the wood there. It's actually the cross sectional area (bulk or "more wood" as you say) and the inherent properties of the wood that control stiffness. It is the weight(mass) that isn't relevant, at least with regard to stiffness.
Quote:
In the avoiding thin/glassy tone thread that I started, more experienced builders than myself cautioned me to not overbuild the top. They said keep the bracing light, and you will achieve greater low end, and in this particular instance since we're taking about a small bodied instrument, would result in a more balanced sound. Do you disagree?
No, I don't disagree. That's right. I wouldn't use the word light though... :) I know by "keeping the bracing light" people mean do not make the braces big and bulky.
I can't come close to Hesh's eloquence, but he makes some good points - about experimenting especially. If you try different things and directly experience the change in sound, it really gives you a lot of useful knowledge and control. Early on, I had a couple 'mule' instruments that constantly got experimented with. Helped me a lot. Best IME not to worry too much about aesthetics with these.
That's maybe the big difficulty about this craft. It's kind of like two things at once: the craft of woodworking, and the art and science of good sound. (whatever that is)
PostPosted: Sat Mar 01, 2014 3:05 am
Thank you again for all of your contributions. They have definitely got me thinking.
Hesh I do like the idea of a mule instrument and just changing the tops around to try different ideas I think this is something that I will look to do. This parlour build is going to be a no frills build anyway that I can take around with me camping, boating etc. So would be ideal for it.
Thanks again.
Sent from my Amazon Kindle Fire HD using Tapatalk
Nick
Follow my musings on getting started in luthiery http://www.tredwellinstruments.co.uk
