It is currently Sun Jul 27, 2025 12:19 am
PostPosted: Mon Aug 23, 2021 7:08 pm
First name: Stuart
Last Name: Gort
These Solera boards were made for Mike Elwell. His classical builds are quite respected.
The idea was to create something very stout and -extremely- accurate. The large Haas cnc was employed. Model in Solidworks. Tool path in Mastercam. The accuracy is .0003" on that machine.
You can see (I hope) that when he clamps anything to this there is no defection of any kind. He's pleased.
StuMusic
PostPosted: Mon Aug 23, 2021 7:28 pm
Last Name: Kincheloe
Probably quite a bit of deflection on his back when he picks them up, though :)
What kind of bit did you use for the dished areas? Square end, ball end, or is there such a thing as a mill with a large radius on the end?
PostPosted: Mon Aug 23, 2021 7:56 pm
First name: Stuart
Last Name: Gort
I used a 1" ball with .01" stepover for each pass. One could build off of the freshly cut surface without needing to sand it.
StuMusic
These users thanked the author Stuart Gort for the post: DennisK (Mon Aug 23, 2021 10:46 pm)
PostPosted: Mon Aug 23, 2021 11:19 pm
Nice to hear from Stuart!
These users thanked the author Chris Pile for the post: Stuart Gort (Tue Aug 24, 2021 9:23 am)
PostPosted: Mon Aug 23, 2021 11:29 pm
First name: Thomas
Last Name: Beltran
City: Los Angeles
Zip/Postal Code: 90014
They work boards are beautiful, like high-end kitchen cutting boards. For those without that equipment, but a router, it is not difficult to build a standard router jig that yields a surface that also does not require sanding. Below are pictures of the jig and the routing in-process, you can see how smooth the finish is, equal to the un-routed mdf surface.
These users thanked the author ThomLuth for the post: Durero (Tue Aug 24, 2021 4:58 pm)
PostPosted: Tue Aug 24, 2021 5:29 pm
First name: Marcus
Last Name: Bailie
City: Kirkland
I am pleased to see you posting, Stuart. I came into CNC recently and found your posts instrumental (see what i did there? hur hur) in my learning.
Cool project, exquisite work!
-Marcus
http://www.bailieguitars.com
Instagram | YouTube
These users thanked the author Marcus for the post: Stuart Gort (Tue Aug 24, 2021 5:48 pm)
PostPosted: Tue Aug 24, 2021 5:53 pm
First name: Stuart
Last Name: Gort
Lovely to hear that. Thank you
StuMusic
