It is currently Wed Aug 06, 2025 4:56 pm
 Post subject: PSA
PostPosted: Fri Mar 16, 2018 7:02 pm
Online
First name: Brad
Last Name: Combs
Just wanted to let you guys know that DNA and Naptha do two different things. One will highlight the ridges in your epoxy pore fill so you can level them. The other will level the ridges for you while simultaneously making a mess of the fill.
Manufacturer suggests if you store them in your own bottles that those bottles be very clearly marked.
The more you know.
Knowing is half the battle.
 Post subject: Re: PSA
PostPosted: Fri Mar 16, 2018 8:38 pm
There is always the sniff test.
Knowing is half the bottle. Hic!
These users thanked the author Clay S. for the post (total 2): dpetrzelka (Fri Mar 16, 2018 9:45 pm) • bcombs510 (Fri Mar 16, 2018 8:52 pm)
PostPosted: Fri Mar 16, 2018 8:49 pm
First name: Daniel
Last Name: Petrzelka
State: Washington
Denatured Alcohol is so much more powerful a solvent than you would think.
These users thanked the author dpetrzelka for the post: bcombs510 (Fri Mar 16, 2018 8:52 pm)
PostPosted: Fri Mar 16, 2018 9:41 pm
First name: Tony
Last Name: Thatcher
City: Bozeman
State: MT
You beat me to it.....
Tony Thatcher
Bozeman, Montana
These users thanked the author mountain whimsy for the post: bcombs510 (Fri Mar 16, 2018 11:00 pm)
PostPosted: Fri Mar 16, 2018 10:16 pm
DNA shouldn't do much to epoxy if it's ratio is right, it's mixed well and it's cured.
These users thanked the author Jim Watts for the post: bcombs510 (Fri Mar 16, 2018 11:00 pm)
PostPosted: Fri Mar 16, 2018 11:01 pm
Online
First name: Brad
Last Name: Combs
Yeah, in the end it wasn’t as big a deal as I had thought. I put it down and walked away. The good news is that I was able to finish up my 30’ radius workboard, so there is that. :)
PostPosted: Sat Mar 17, 2018 11:02 am
Works real good on livers.
PostPosted: Sat Mar 17, 2018 12:22 pm
City: Escondido
Zip/Postal Code: 92029
I wouldn’t have thought to use either. What do you wipe naphtha on for?
PostPosted: Sat Mar 17, 2018 1:08 pm
First name: Jay
Last Name: De Rocher
City: Bothell
State: Washington
Ok, based on the posts above, I'm confused which one is which. I always put an epoxy/ethanol 50:50 wash coat on as my last epoxy coat and the ethanol in that doesn't cause any problem for the epoxy already on. I haven't tried naptha on epoxy.
I don't know about Brad, but I use naptha to clean fine sanding dust out of wood and it's really good for highlighting surface flaws like small scratches. It doesn't evaporate as quickly as ethanol so you have a longer viewing time.
These users thanked the author J De Rocher for the post: bcombs510 (Sat Mar 17, 2018 3:06 pm)
PostPosted: Sat Mar 17, 2018 1:56 pm
DNA can soften uncured epoxy more or less depending on the denaturant . MEK is sometimes used and will soften epoxy. Epoxy takes a few days to fully cure so that could be a factor also. I think in some cases the epoxy will re-harden without ill effect.
PostPosted: Sat Mar 17, 2018 3:09 pm
Online
First name: Brad
Last Name: Combs
Sorry, this post was intended to be more of a joke highlighting what an idiot I can be at times. :D
I use the naphtha same as Jay. When I’m leveling epoxy it can sometimes be hard to see the remaining imperfections. Wiping naphtha on highlights them for me so I can take care of it.
Brad
Users browsing this forum: doncaparker and 37 guests
