It is currently Wed Aug 06, 2025 7:28 pm
 Post subject: HVLP Setup
PostPosted: Sat Feb 10, 2018 3:23 am
First name: David
City: Napa
Zip/Postal Code: 94558
I need to get an HVLP setup for doing mostly wood working and an occasional instrument I would would like to spend about $400-700. Anyone have a model or brand they really like?
 Post subject: Re: HVLP Setup
PostPosted: Sat Feb 10, 2018 6:28 am
Lucky you, your budget stretches to this range - https://www.ebay.com/itm/Fuji-Platinum-Mini-Mite-Turbine-2803-T75G-Stage-Turbine-System-w-Gravity-Gun/263051151752?epid=1109985423&hash=item3d3f120988:g:dkoAAOSwi7RZNqWY
Get the 1 mm cap for waterbourne lacquers.
Oh, and and the whip hose is an essential really, I've done it with and (once only) without.
If you can stretch a little more, this upgrade https://www.ebay.com/sch/i.html?_from=R40&_sacat=0&_nkw=Fuji+Mini-Mite+4&_sop=15
PostPosted: Sat Feb 10, 2018 8:40 am
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
I'm with Colin, if you can stretch the budget, go with a 4 stage Fuji. It will cover most finishes when using the correct cap set. Spraying without a whip hose just once will make you run out and get one.
Alex
PostPosted: Sat Feb 10, 2018 1:50 pm
First name: David
City: Napa
Looks like it night be worth it to bump up to the Q4.... which size tip is best for Laquer?
PostPosted: Sat Feb 10, 2018 2:07 pm
Nitrocellulose? I believe maybe a 1.3mm, but check with others, See http://www.fujispray.com/choosing-the-correct-air-cap-set/
PostPosted: Sat Feb 10, 2018 3:58 pm
First name: David
City: Napa
I ended up with this unit.
https://www.amazon.com/gp/product/B015R ... UTF8&psc=1
PostPosted: Sat Feb 10, 2018 4:30 pm
That should do the trick :mrgreen:
PostPosted: Sat Feb 10, 2018 6:08 pm
First name: Alex
Last Name: Kleon
City: Whitby
I've got a Q4 Gold, and love it! Yours will be quieter, David, and you'll never regret buying better!
Alex
Users browsing this forum: ptourin and 10 guests
