It is currently Thu Aug 07, 2025 1:40 pm
PostPosted: Sat Dec 09, 2017 1:04 pm
First name: Freeman
Last Name: Keller
I have built necks both ways - with the nut on the flat part and on the angled headstock. I think Gibson mostly does it the first way, Martin the second. I guess that when I put the adjuster in the headplate I tend to put the nut on the flat, when I put the adjuster in the soundhole I put the nut on the angle.
For what it is worth I almost always use a double acting rod with a small (hex key) socket. In normal action the rod would be pushing down a the nut and heel end and up in the middle. I also use a 1/4 inch thick nut - so putting it on the flat just makes the neck that much longer.
I can't think of why one might be better but I'm curious what you use and why.
PostPosted: Sat Dec 09, 2017 1:15 pm
Both, can't think of a reason why one is superior to the other either beyond folks who build instruments closely following a particular builder's traditions such as CFM, OG, etc.
Regarding my phrase, the serviceability quotient I still don't see any advantages of either over the other provided that neither is inlaid... into a dovetail cavity of sorts. I have seen this before and expressed a few choice words as a result...
A related discussion is if the nut ends are on the curves of the headstock or a relative flat area. I built one guitar with the nut ends on a curve and this resulted in needing to hollow out the ends of the nut for appearances. Although just another day in the neighborhood I can see how some may find this to be a harder nut to produce well and have it still look eloquent.
Also related are finished in nuts such as CFM and OG did/do. I like the look and with today's light cured composite dental filling technologies the nut need never need to be removed making scoring the finish not a consideration anymore.
PostPosted: Sat Dec 09, 2017 3:46 pm
Online
I do it on the flat of the neck, as I find it easier to make it that way, as well as easier to make the nut.
PostPosted: Sat Dec 09, 2017 6:54 pm
Last Name: Colbert
City: Anacortes
+1 for on the flat...
PostPosted: Sun Dec 10, 2017 12:08 am
Angled for me because I like the way it looks.
PostPosted: Sun Dec 10, 2017 6:44 am
First name: Willard
Last Name: Guthrie
City: Cumberland
State: Maryland 21502
Zip/Postal Code: 21502
Country: United State
For deep-set nuts glued in an overly comprehensive fashion, the angled bottom nut seems a bit easier to release; when nuts are glued properly (we prefer a very small dot or at most two of medium CA on the face of the nut resting against the fretboard), there is no real difference. I prefer the look of the angled bottom for Martin and other historical examples, but I am uncertain as to whether most players will find a reason to care.
- Beth Brower
Users browsing this forum: J De Rocher, meddlingfool and 37 guests
