It is currently Thu Aug 07, 2025 4:35 pm
 Post subject: Plexi jig
PostPosted: Fri Oct 20, 2017 5:09 pm
Last Name: Denvir
City: Baltimore
State: ON
Zip/Postal Code: K0K 1C0
I want to make a jig out of plexi for cutting a channel for a back strip. Any thoughts on the best way to cut the plexi? Or should I just stick with Baltic ply?
Thanks in advance
 Post subject: Re: Plexi jig
PostPosted: Fri Oct 20, 2017 5:56 pm
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
Polycarbonate sheet is a better choice, Steve. Plexi cracks and shatters easily, IIRC. I cut it on the table saw. If I'm ripping poly that is under 1/4" thick, I'll double stick tape a sacrificial piece of wood on top of it to keep it from riding up on the blade. There's a shop near me that sells all kinds of plastics. They usually have a rack with odds and ends pieces, as well as metal and aluminum in all shapes and sizes.
Alex
PostPosted: Sat Oct 21, 2017 5:02 am
You don't mean one of these do you buddy ;)
These users thanked the author Hesh for the post (total 2): klooker (Sat Oct 21, 2017 8:42 am) • Clinchriver (Sat Oct 21, 2017 5:27 am)
PostPosted: Sat Oct 21, 2017 6:45 am
Plexi routs well. If you use a table saw to cut it an ATB (alternate top bevel) blade with a high tooth count might be a good choice.
PostPosted: Sat Oct 21, 2017 9:09 am
First name: Fred
City: Winnipeg
First thing that popped into my head also. Mind you I am more or less out of commission for guitar building and have been planning out some amps I want to build.
These users thanked the author printer2 for the post: Hesh (Sat Oct 21, 2017 1:22 pm)
PostPosted: Sat Oct 21, 2017 9:39 am
Last Name: McNerney
City: Ottawa
State: On
Country: Ca
I like BB partly because if you accidently run a bit in to it it's easily repairable. I also think it might be more ridged in 1/2" or 3/4" thickness. Of course it depends on the overall width you make the guide/jig . I just made one of 1/4" and 10" wide to cut a sliding dovetail on a piece of furniture & it stayed ridged. I guess 10" wide of plastic is ridged too.
Mike McNerney
PostPosted: Sat Oct 21, 2017 12:07 pm
State: West Somerset
Country: UK
Yes I would go for polycarbonate or poly acrylate. Machine with ordinary woodworking tools, though I find using a disk sander can leave a bit of melted material on the edge - possibly because it's time to change the abrasive!
PostPosted: Sat Oct 21, 2017 3:59 pm
Last Name: Denvir
City: Baltimore
State: ON
Aw geez, don’t encourage him. :-)
These users thanked the author JSDenvir for the post: Hesh (Sun Oct 22, 2017 5:30 am)
Users browsing this forum: Freeman and 7 guests
