It is currently Fri Aug 08, 2025 3:03 pm
 Post subject: purfling lines...
PostPosted: Tue Jan 10, 2017 4:48 pm
Last Name: Sollod
How were these purfling lines installed? A gramil could work on the sides with edges, but not sure about the other side where a gramil wouldn't reach...
www.swiftcreekguitars.com
 Post subject: Re: purfling lines...
PostPosted: Tue Jan 10, 2017 5:14 pm
CNC? Either that or a really good jig to follow.
PostPosted: Tue Jan 10, 2017 5:39 pm
First name: Aaron
Looks like an inlay.
PostPosted: Tue Jan 10, 2017 5:50 pm
Last Name: Kincheloe
Gramil could work. The straight lines would be easy enough to do with a knife and ruler. But I think Aaron is right, and the triangles were inlaid rather than created in-place. The curl in the maple inside the triangles doesn't look exactly the same as the curl outside... though it's close enough that I'm not sure.
If they are inlays, then they were probably done while the bridge was still rectangular, and then it was carved to fit the inlays rather than the other way around.
These users thanked the author DennisK for the post: Aaron O (Thu Jan 12, 2017 12:58 pm)
PostPosted: Thu Jan 12, 2017 11:08 am
Last Name: McGlynn
City: Scotts Valley
Zip/Postal Code: 95066
If I was making that part I'd be thinking "router templates", there would be some careful knife and chisel work at the corners to get the sharp points no matter how you approach it I think.
Blog on Making Stuff: http://www.McGlynnOnMaking.com
PostPosted: Thu Jan 12, 2017 12:32 pm
Some people have a steady hand. I'd bet Doug Ingram wouldn't have a problem with it.
These users thanked the author Clay S. for the post: Alex Kleon (Thu Jan 12, 2017 12:35 pm)
PostPosted: Thu Jan 12, 2017 2:57 pm
Last Name: Beaver
City: Lake Forest
I have never done bridge inlays but if I was to do one I would do it like my headstock purfling inlay.
I would use the Stew Mac dremel base with edge guide. I would use a board as a straight edge to cut the straight channel. The points would have to be finished off with an exacto knife.
Joe Beaver
Maker of Sawdust
PostPosted: Thu Jan 12, 2017 3:33 pm
First name: Allen
Last Name: McFarlen
City: Mt. Sheridan
State: Qld.
Zip/Postal Code: 4868
Dead easy with a CNC.
Allen R. McFarlen
Facebook
Cairns, Australia
PostPosted: Thu Jan 12, 2017 6:05 pm
Last Name: McDonald
City: Okanagan Centre
State: British Columbia
Zip/Postal Code: V4V2H6
On Furniture, this would be called stringing.
Typically it would be done with a tool called a scratch or a scratch cutter.
Lie-Nielsen and Veritas both make various stringing tools.
PostPosted: Sat Jan 14, 2017 1:36 pm
CNC's are cool . . . and expensive . . . and I bet that job could be done with a Dremel and the Purfling/Soundhole Router Guide from StewMac.
Users browsing this forum: Bing [Bot], KyleU and 12 guests
