It is currently Fri Aug 08, 2025 9:39 pm
PostPosted: Mon Dec 12, 2016 9:31 am
Here is the latest Luthier Tips du Jour video - In this video I share some ideas about how to radius braces.
This video as well as all my other videos are available via my website, http://www.obrienguitars.com/videos , LMI's website or on youtube.
These users thanked the author Robbie O'Brien for the post: GRS (Mon Dec 12, 2016 9:51 am)
PostPosted: Mon Dec 12, 2016 9:51 am
Just say-in -- this method is hard to beat, takes less than a minute per brace.
Ken Cierp
PostPosted: Mon Dec 12, 2016 10:28 am
First name: Rob
Last Name: Evans
City: Framingham
State: Ma
Zip/Postal Code: 01701
Any one besides me have a concern over a sanded surface at the brace/top joint? I always refine the surface with a plane before i glue it down.
PostPosted: Mon Dec 12, 2016 10:44 am
I've done it both ways but I cut mine with a plane now. None of the sanded joints have come apart so far.
PostPosted: Mon Dec 12, 2016 11:26 am
LOL... I like the self sanding part that's somthin' else!
I just use a plane too. Once you rip of a full length paper thin curl you are done. I don't think that sanding vs planing makes a difference though, on paper yes a physicist can show that a planed surface is better but...
PostPosted: Mon Dec 12, 2016 3:25 pm
City: Tyler
When I first started out, I had a jig for everything and probably 3 different ones for arching braces. I figured out that in some cases the jig solves a problem but isn't much better than without the jig. I just use a plane. But, if it helps, then use it.
PostPosted: Mon Dec 12, 2016 5:41 pm
State: Tennessee
I use a planed edge, method is a combination of Marios and Bruce Sexauer. While my Veritas Shoot board plane might be overkill the results speak for themselves.
PostPosted: Tue Dec 13, 2016 8:24 am
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Zip/Postal Code: 64081
I use a plane and then LMI sanding jig, except I use 120 grit on the jig . either way will work
These users thanked the author ernie for the post: GaryG. (Sat Dec 17, 2016 6:42 pm)
Users browsing this forum: Cal Maier and 43 guests
