It is currently Tue Aug 12, 2025 6:27 pm
 Post subject: making weak hide glue?
PostPosted: Mon Apr 25, 2016 9:56 pm
I'm wanting to string up a guitar in the white and want to make a temporary bond on the fingerboard extension and bridge for easy removal.
I was wondering if I dilute my hide glue a little will this do what I want?
PostPosted: Tue Apr 26, 2016 3:28 am
Might work. I don't know. I'd probably just use a few dots of Elmers.
Ken Franklin
clumsy yet persistent
PostPosted: Tue Apr 26, 2016 5:23 am
A dot of glue under finger board extension will do the job -- An improperly/poorly glued bridge can cause unwanted excitement (and perhaps damage) SM sells special bridge pin hole bolts to use for temporary assembly -- I think that is a better choice.
Ken Cierp
PostPosted: Tue Apr 26, 2016 7:37 am
Last Name: Farmer
City: Durango
State: CO
+1 avoiding a temporary glue up of the bridge. The hollow Stew Mac bolts are really handy every once in while. A totally safe way to string up a bridge that's either off or hanging on by a thread.
I think a temp glue up of the extension would be ok.
In my experience, it takes a lot of dilution to weaken hide glue. Not until a standard mix of my 192 gram strength glue is cut again with 50% water does it really start to give up.
I would grab some scrap spruce and hardwood and make some quick samples. I think you will be surprised.
Another option is to put a little piece of newsprint on the spot you glue. The glue line tends to split through the paper.
PostPosted: Tue Apr 26, 2016 8:58 am
First name: Tom
Last Name: West
State: Nova Scotia
Think this is common in violin world and would be my choice. The fingerboard extension does not need to be glued if you are worried about integrity. I have strung up quite a few guitars without this glued and left some up to 2 or 3 years. My thoughts are that it adds very little to the overall strength.
Tom
PostPosted: Tue Apr 26, 2016 2:08 pm
I put a tiny bead of 192 hide on the back edge of a 1 by 6 Bridge 25.4 guitar about four years ago and it is still Rock Solid. I haven't tried to get it off yet. I think if I do it again, I will use an even tinier bead!
Users browsing this forum: ChuckB and 17 guests
