It is currently Fri Aug 15, 2025 2:13 pm
PostPosted: Sat Nov 22, 2014 5:33 pm
Last Name: smith
City: hemet
State: ca
Zip/Postal Code: 92543
I have a certified calibrated digital Hygroset that agrees with my Caliber3 is why I know those dial hygros Hesh talked about are inaccurate. I would rather have one that is accurate than use a sharpie.
So again, anyone can direct me to an innexpensive sling that is accurate?
PostPosted: Sat Nov 22, 2014 5:59 pm
You just need one decent thermometer. Pull air across the bulb with a vacuum cleaner, done dry and then wet. Record both readings. That's really all a sling psychrometer is.
PostPosted: Mon Nov 24, 2014 12:38 pm
First name: James
Last Name: Bolan
City: Nashville
State: Tennessee
Thanks Hesh.Picked up a couple.I also have had trouble convincing customers to humidify their guitars in the winter.These will go to a couple of customers .
James W Bolan
Nashville Tennessee
PostPosted: Mon Dec 08, 2014 9:19 am
I did some testing on the one I recently bought and it pretty much matches up with Hesh's findings. In the image below the psycrometer measured 50% RH so it's only 'off' by about 5% maybe a bit more but I tested it inside the shop and outside and it was consistently off. I think for 8 bucks it's something good to have around if you just test it every few months or so.
PostPosted: Mon Dec 08, 2014 10:51 am
First name: EddieLee
Last Name: Brown
First I do like these relatively inexpensive analog devices because I can calibrate then to my wet/dry bulb http://www.amazon.com/Reed-WD-5-Wet-Dry ... hygrometer .
Second is that the 2 I received read on the high side. However, I like to have hygrometers scattered through out the house. These do seem to work well once calibrated, easy to read at a distance, and do not need to have the batteries replaced every year are so ;-)
Thanks Hesh,
_____________
EddieLee
PostPosted: Mon Dec 08, 2014 6:02 pm
Finally got home to find my one had arrived, but was reading 65% RH when it was actually about 40%.
Take apart, needle off. put back on at 40%, add a dab of superglue, done.
These users thanked the author Colin North for the post: rtpipkin (Mon Dec 08, 2014 7:51 pm)
