It is currently Sat Aug 16, 2025 9:37 am
Post new topic Reply to topic  [ 38 posts ]  Go to page Previous  1, 2
PostPosted: Wed Oct 08, 2014 6:19 pm
Last Name: smith
City: hemet
State: ca
Zip/Postal Code: 92543
So Ed, with your set up is the deflection you usually aim for .25" ?
PostPosted: Wed Oct 08, 2014 7:18 pm
No, less. .200 is probably a better starting point, then assess and adjust accordingly...
PostPosted: Wed Oct 08, 2014 8:56 pm
Last Name: Arnold
City: Newport
Zip/Postal Code: 37821
Quote:
Might also use 5/16" bracing instead of the usual 1/4"...
12 strings often have 3/8" bracing.
PostPosted: Wed Oct 08, 2014 9:17 pm
Went with 5/16. According to preliminary data, I should be pretty close to right on the money...I'll know more in a few weeks...
PostPosted: Sat Oct 11, 2014 5:42 am
Last Name: Lee
City: Albany Creek
State: QLD
Zip/Postal Code: 4035
Trevor Gore wrote:
I must encourage you to look in that big black book more often, Ed!
Trevor, after seeing many references to the books, I decided to do some checking. I have several books bought in the last few years, but a week ago bought your books. At the cost they are the best value for money. Now I might actually understand rather than blindly following plans. As a member of AAMIM I will be sharing my find at the next meeting.
PostPosted: Sat Oct 11, 2014 10:10 am
They're awesome!
PostPosted: Sat Oct 11, 2014 6:05 pm
First name: Trevor
Last Name: Gore
City: Sydney
meddlingfool wrote:
They're awesome!
Thanks, Ed!
Thanks, Mike! Make sure you take yours home with you !
http://www.goreguitars.com.au
PostPosted: Tue Oct 14, 2014 1:54 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
J De Rocher wrote:
I was curious enough about this that I set up a deflection rig like Ed's and did the test using an unsanded spruce plate (0.175 thick), a dial gauge, and two weights labeled as being 3 lbs each but were actually 3.6 and 3.7 lbs.
3.6 lb, deflection = 0.107
7.3 lb, deflection = 0.185
The deflection will be linear up to a point, then it will become non-linear. You passed the point of linearity in your test. Try 1 lb, then 2, then 3, etc. Plot it out. Back in my college days, this was covered under something called "Strength of Materials".
PostPosted: Tue Oct 14, 2014 2:50 pm
First name: Jay
Last Name: De Rocher
City: Bothell
State: Washington
I'm sure you're right about linearity at small deflections. From what I've read, it seems that the weights people use for this are in the neighborhood of five pounds. I didn't want to double that to ten pounds because I expected it would give very non-linear results. I chose those weights to bracket five pounds. It would be interesting to know at about what amount of deflection the transition to non-linearity occurs with a setup like Ed's. It seems there would be a sweet spot where the deflections would be in the linear range and be big enough to measure accurately.
PostPosted: Tue Oct 14, 2014 3:07 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
If you really want to warp your head... we can go back to the discussion of Go-Bars and maximum normal force (turns out for a 1/4" fiberglass Go-Bar, you get about 7 pounds of normal force no matter how much deflection)
I actually understand that.
What I don't understand is why they are called Go-Bars.
PostPosted: Tue Oct 14, 2014 3:46 pm
laughing6-hehe
PostPosted: Tue Oct 14, 2014 4:47 pm
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
SteveSmith wrote:
laughing6-hehe
Because they go flying past your head if you aren't careful?
Alex
PostPosted: Tue Oct 14, 2014 5:31 pm
First name: Trevor
Last Name: Gore
City: Sydney
One of the advantages of using a tap method (dynamic vs. static) to work out the stiffness (Young's modulus) is that you don't get excessive deflections. I find it's quicker, too. It relies on having rectangular, flat wood of uniform thickness, same as deflection (static) methods.
Users browsing this forum: TimAllen and 9 guests
