It is currently Sat Aug 16, 2025 6:25 am
 Post subject: Demi cutaway
PostPosted: Wed Oct 08, 2014 8:11 am
Last Name: Orr
Hi can anyone point me in the direction of instructions on how to install a demi cutaway on a new build I am planning? I have tried the search facility here and MIMF and You Tube and Google searches without any success,
Cheers, Bob
 Post subject: Re: Demi cutaway
PostPosted: Wed Oct 08, 2014 11:26 am
Last Name: G
Burton posted how he does one, along with the rest of his build here:
viewtopic.php?f=10117&t=29270
The cutaway part isn't obvious until well into the build, either page 4 or 5.
cheers, SteveG
PostPosted: Wed Oct 08, 2014 12:54 pm
Last Name: Colbert
City: Anacortes
Jeffrey Yong did an article in American Lutherie, issue 110/ summer 2012. Lots of pictures!
PostPosted: Wed Oct 08, 2014 2:03 pm
Last Name: Orr
Thank you both, exactly what I was looking for! Thanks.
CHeers, Bob
PostPosted: Thu Oct 09, 2014 2:59 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
So what is the point of a half cutaway? It doesn't really give better hand access compared to a normal cutaway, and it appears 10 times harder to do, requiring multiple piece neck blocks and thus incompatible with a traditional dovetail construction. Well, I'm sure it can be done but once you steam a multi piece neck block, you separate more than just the neck....
Maybe I'm just really traditional.
Typhoon Guitars
PostPosted: Thu Oct 09, 2014 4:40 pm
Looks cool......
Much better access that a non cutaway - look at the angle your hand is at playing at the dusty end.
Built with CF buttressing, like Burton does, much less chance of needing a reset.
Could also simply be built with a bolt on bolt off neck, no steaming then.
Some people like the challenge too.
PostPosted: Tue Oct 14, 2014 2:28 pm
If the loss of air volume in the box affects the sound (and there's no data either way, so far as I know) then a demi-cutaway should affect it less.
