It is currently Sun Aug 17, 2025 10:26 pm
PostPosted: Wed Jun 25, 2014 6:13 pm
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
Zip/Postal Code: 75044
cutting out the fretboard and fret markers, nut set in .118 from 0 fret position for nut compensation...board next to it is 1/4 inch mdf I used for a practise cut first..
MK5acoustics.com
PostPosted: Wed Jun 25, 2014 6:17 pm
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
oh I slotted and radiused the fretboard before machining, fret slots cut with a stewmac blade and Lmi template, radiused on a jig Todd Stock had posted using a router..
MK5acoustics.com
PostPosted: Thu Jun 26, 2014 12:33 am
Why did you not use the CNC to radius the board and cut the slots?
PostPosted: Thu Jun 26, 2014 6:13 am
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
right now I am not set up for 3d machining which is required for radiusing , and didn't have a .023 bit to cut the slots , cutting the slots on a table saw is fast and easy.
MK5acoustics.com
PostPosted: Thu Jun 26, 2014 10:14 am
looks nice!. btw you don't need 3d to machine a constant radius fretboard. it is not a requirement. a true compound? -yes, but not a straight radius if that is what you are making.
what software are you using?
PostPosted: Thu Jun 26, 2014 10:52 am
Last Name: Lee
Country: Wales U.K.
The position markers are not equi-spaced from the fret slots. Is that deliberate?
PostPosted: Thu Jun 26, 2014 12:16 pm
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
Using v carve pro, camera angle makes the markers look off
MK5acoustics.com
PostPosted: Thu Jun 26, 2014 12:22 pm
How did you index the slots to get the taper and nut in the correct relationship with the slots?
Looks like you over-cut the nut location... too close to the 1st fret.
It's not your camera angle, it's the location of the cut. Everything got shifted downward...
PostPosted: Thu Jun 26, 2014 12:27 pm
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
Measured distance between nut, less .118 for comp and first fret dead on
MK5acoustics.com
PostPosted: Thu Jun 26, 2014 12:34 pm
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
You can see 0 fret position slot in 3rd pic
MK5acoustics.com
PostPosted: Thu Jun 26, 2014 1:15 pm
First name: Ringo
Sorry to be a downer, but .118" is waaaay too much nut compensation... maybe you were thinking of saddle compensation? .02-.03" is usually plenty at the nut.
Last edited by James Ringelspaugh on Thu Jun 26, 2014 2:12 pm, edited 1 time in total.
PostPosted: Thu Jun 26, 2014 1:43 pm
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
Each string is individually compensated by machining nut, see Trevor Gore books, .118 is needed basically for low e, comp is from 0 fret position, the saddle is also compensated as well
MK5acoustics.com
PostPosted: Thu Jun 26, 2014 1:44 pm
I think most people use about .012 by default. That's what you get when you use the (LMI) fret template. What type of CNC is that?
PostPosted: Thu Jun 26, 2014 1:50 pm
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
Machined nut
MK5acoustics.com
PostPosted: Thu Jun 26, 2014 2:16 pm
First name: Ringo
Ah, I see... I guess it doesn't hurt to have extra bone to work with if you don't mind a little extra file work
PostPosted: Thu Jun 26, 2014 4:42 pm
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
Nut also machined on cnc
MK5acoustics.com
Users browsing this forum: Bing [Bot], DennisK and 40 guests
