It is currently Tue Aug 19, 2025 9:05 pm
 Post subject: Chamfer router bits
PostPosted: Wed Jan 29, 2014 11:01 am
Does anyone know of a source for a 45 degree chamfer bit with a 1/8" shaft and roller bearing on the end? I've searched the internet without success. I have found 1/4" shaft bits with the bearing. I've also found them with a 1/8" shaft but no bearing. I find the bearing is necessary to avoid burnishing the bearing surface on the inside of the string slots. The 1/8" shaft is necessary to allow use on a small rotary tool to get all the way around the string slot on the back of the head. A laminate router base hits the back of the neck with about an inch to go on the slot.
Any sources or ideas?
Max
Max Bishop
Brighton, Michigan
 Post subject: Re: Chamfer router bits
PostPosted: Wed Jan 29, 2014 2:41 pm
The porter cable lam trimmer offers an offset router base that might allow you to get closer
PostPosted: Wed Jan 29, 2014 4:57 pm
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
You can make your own offset base by attaching a piece of wood or UHMW to the existing base.
Alex
PostPosted: Wed Jan 29, 2014 8:07 pm
The offset router base actually moves the router bit to the edge of the base using a toothed gear and belt arrangement. I might even have one around for a 310 trimmer although I no longer have a 310 router to go with it . :(
The offset I use is with my 7310 routers and still available:
http://www.homedepot.com/p/Porter-Cable ... /203162764
Depth adjustment is limited and it may be necessary to fabricate different thickness sub bases to get to the depth you want to use.
PostPosted: Fri Jan 31, 2014 8:57 am
Thanks for the input. I found an offset router base for the Bosch Colt and I have one of these. Looks like it will do what I want.
Thanks again,
Max
Max Bishop
Brighton, Michigan
Users browsing this forum: No registered users and 45 guests
