It is currently Wed Aug 20, 2025 12:45 am
Post new topic Reply to topic  [ 28 posts ]  Go to page Previous  1, 2
 Post subject: Re: neck angle
PostPosted: Sat Jan 04, 2014 7:01 pm
First name: Theo
Last Name: Delaca
City: Fbks
State: Ak
Zip/Postal Code: 99712
It can get pretty dry here in the winter, noticing the garage door and 4 wheeler in the background, I thought humidity. I wondered whether the geometry issue could be humidity related and the soundboard a symptom of that.
PostPosted: Sat Jan 04, 2014 8:53 pm
First name: Joey
Last Name: Holliday
City: Palmetto
Zip/Postal Code: 34221
Theo wrote:
Being the middle of winter could humidity be a problem? How is the radius of your soundboard?
Yeah I've all but given up trying to humidify the shop. It's in my garage and the only thing between the shop and the outside is a poorly insulated garage door. I never open the door but when it's -48 outside like it was last week the heater pretty much runs constantly just to keep the garage between 50-55 degrees. I still run the humidifier although it's probably futile but the humidity is usually 22-25% regardless of what I do. I figure- at least it's constant. I wouldn't sell this guitar, for me it's about the experience of the build and having something to play.
The geometry of the top where the X brace is still has a nice dome. Behind the X brace it flattens right out almost dead flat. I screwed up the dovetail on the first neck, but luckily my plan was for a baritone. It would have been way to low as a baritone and the neck screw up would have made it even worse. So I just changed the scale length from 27.5" to 25.7, shortened the neck with the new dovetail and moved the bridge a bit forward (back up on the domed geometry of the top. It seems like it will work out but first I have to make another bridge.
PostPosted: Mon Jan 06, 2014 2:15 pm
First name: Joey
Last Name: Holliday
City: Palmetto
It's warned up from -48 to 22 degrees. Humidity is now all the way up to 36% in the shop. How long should I let it sit at that level (assuming the deep freeze doesn't return) before gluing the bridge? Once complete it will live in a 40% humidity controlled room in my house.
Users browsing this forum: Bing [Bot] and 38 guests
