It is currently Wed Aug 20, 2025 11:22 am
Post new topic Reply to topic  [ 27 posts ]  Go to page Previous  1, 2
 Post subject: Re: top potato chipped
PostPosted: Tue Nov 05, 2013 8:54 am
First name: Gil
Last Name: Draper
City: Knoxville
State: Tennessee
DennisK wrote:
Goodin wrote:
The top isn't the issue, it's the braces that will cause potato chip. Braces being much thicker than tops will take longer to acclimate.
Why would the braces matter? Wood changes very little in the longitudinal direction, and they're so narrow, any width change would be very small. Maybe a 1/2" wide upper transverse brace's width shrinkage could affect the upper bout angle a tiny bit, but the others, being usually 5/16" at most, should be unnoticeable... and if they're wet and drying out, it would be in the convex direction anyway.
Perhaps you are correct. Just my observations...I have seen bracewood go bananas in my shop (off the guitar) but most of the movement was cross grain and not longitudinal, but it did move some longitudinal.
PostPosted: Tue Nov 05, 2013 9:50 am
"80% seems high, but the conventional wisdom is to build in the same RH as where the guitar will live after it's built. Usually people in the climate I live in build around 40-50% RH."
"So if a musician travels between varying RH area (like a gig in a tropical rainforest, followed by a gig in say Dubai a week later) would have a hard time with his guitars?"
One thing to keep in mind is that it is not just the climate that affects the humidity it is also the "microclimate". Moving from a humid outdoor environment to an air conditioned room can drop the humidity tens of percentage points immediately. Even when building in a humid climate it is better to build on the lower end of the humidity range.
