It is currently Wed Aug 20, 2025 9:49 pm
PostPosted: Sat Oct 12, 2013 6:59 pm
Last Name: Sollod
Is it really necessary to install an end pin in a steel string? I guess it's customary, but if you don't intend to stand up and use a strap... Another thing is if you ever intend to install a pickup, it would be easier to drill to the appropriate size rather than going from a holed that was drilled for an end pin... Just wondering what folks think. Should I go ahead an put in that end pin?
www.swiftcreekguitars.com
PostPosted: Sat Oct 12, 2013 7:16 pm
Last Name: Flindall
City: Peterborough
Personally I don't think an endpin is a must. Without it, it gives the owner the ability to "customize" their guitar which many like to do. And you save a few bucks in the process :)
Rob Flindall
Flindall Guitars
http://www.flindallguitars.com
https://www.facebook.com/FlindallGuitars
PostPosted: Sat Oct 12, 2013 7:18 pm
I don't unless its requested...
PostPosted: Sat Oct 12, 2013 7:20 pm
First name: Tom
Last Name: West
State: Nova Scotia
Stephen:
I have seen guitars without and that OK with me, but one must realize that someone else who gets the guitar might want something to use for a strap. I stopped using tapered end pins a number of years back when someone did a DIY pick-up installation on one of my guitars. Did not go too well, so from then on I decided to just use pick-up jacks in all my guitars. I think there is less likely to be as much damage from a drop as compared to tapered pin.
Tom
PostPosted: Sat Oct 12, 2013 8:05 pm
City: chicagoland
State: illinois
its nice to equip it with a hard point to rest on if it needs to be set down without a stand being handy, or a case....which is 99.9% of the time for me
PostPosted: Mon Oct 14, 2013 1:32 pm
First name: Daniel
Last Name: Minard
City: Powell River
State: BC
On a "spec" instrument, I don't install strap pins. When the instrument sells, I'll install pins, (at no charge) if the customer wants them.
Users browsing this forum: DennisK and 32 guests
