It is currently Thu Aug 21, 2025 2:37 am
Post new topic Reply to topic  [ 28 posts ]  Go to page Previous  1, 2
PostPosted: Sun Sep 22, 2013 8:11 am
"Building guitars is nothing compared to building your own character."
Yes, you are right, be it good or bad! :lol:
It's nice to see how different people approach the same problem. I have found better ways to do things by reading how others do them. I might be able to think of a way, but not necessarily the best way to do things.
I generally grab a fine file to level shell side marker dots before doing the final sanding on the neck, but an emory board or a hard backed sanding block will work too. I don't like setting the dots below the level of the wood and filling over them, but some have good success with that method.
PostPosted: Sun Sep 22, 2013 12:17 pm
When I wasn't sure how to adhere the 220 to the stick of maple I used, I almost started a thread. But then I though, "Nah. I'll just use my Super 77," and it worked like a charm.
<That was meant in fun>
The sanding block worked perfectly. And yes, a little embarrassed that I didn't think of it immediately, but not that I started a thread on a luthiers forum to get a quick and effective solution to a problem.
PostPosted: Sun Sep 22, 2013 1:39 pm
Indeed. Even just to answer the question for someone else as well....
