It is currently Thu Aug 21, 2025 8:28 am
 Post subject: Adventures in Finishing
PostPosted: Tue Aug 27, 2013 6:23 pm
Last Name: Beaver
City: Lake Forest
Being a big fan of KTM-9, I decided I would give their SV a try. I was impressed with the material, sprayed really well, less likely to have sags than KTM 9 and no blue haze!
I sprayed 12 medium coats (6 one day, six the next, light sanding between days) and let it set up for about 10 days. It sanded quite well and it was ready for the buffer in no time. It buffed up well and I was ready for final assembly, or so I thought.
Seems when you turned it just the right way, in the right light, you could see a squiggly pattern under the finish. It looked like the trapped water you see under a tinting film put on glass using water. But in my case it didn’t just evaporate away.
My lay up for this guitar: Zpoxy on bare wood, level sanded followed by two light coats of wax free spray shellac. Light level sanding again and then the SV.
Using the shellac is also knew to me. I think the problem came from sanding the shellac to the point where it wasn’t a complete coat.
Anyone have any experiences like this?
Joe Beaver
Maker of Sawdust
PostPosted: Tue Aug 27, 2013 8:19 pm
Last Name: Cox
I think you hit it... Could be from sanding thru the shellac....
I had some really weird experiences when using shellac for an undercoat....
Sure - most things stick to it... but most things *DON'T* stick to it as well as they stick to bare wood.... Then - there's a slight difference in the way the shellac pops the underlying grain vs other finishes... so if you have places where there's no shellac - then places where there's shellac... you have places where the top coat sticks differently than it does on other places.... and places where the topcoat pops the grain 1 way, and places where the shellac popped the grain some other way...
PostPosted: Tue Aug 27, 2013 8:24 pm
Last Name: Beaver
City: Lake Forest
John, I think you may be right. It was a pain to fix
Joe Beaver
Maker of Sawdust
PostPosted: Tue Aug 27, 2013 8:27 pm
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
Was it a rattle can of shellac that you used, Joe? If it was, I'm pretty sure the Zinser type shouldn't be used under a finish.
Alex
PostPosted: Tue Aug 27, 2013 8:29 pm
Last Name: Beaver
City: Lake Forest
Alex,
It was the zinser. Weird looking pattern deep under the finish.
Live and learn
Joe Beaver
Maker of Sawdust
These users thanked the author Joe Beaver for the post: weslewis (Wed Aug 28, 2013 6:01 am)
PostPosted: Tue Aug 27, 2013 9:54 pm
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
Zip/Postal Code: 75044
I have been using target coatings em 1000 under the em 6000 instead of shellac....
em 1000 is clear and great for dyes,
MK5acoustics.com
PostPosted: Wed Aug 28, 2013 1:42 am
Last Name: Beaver
City: Lake Forest
With KTM 9 I just spray it on bare wood on the soundboard and over z-poxy on the rest of the guitar.
On this one to fix it, I sanded the bad areas down to at least z-poxy and some places to the wood. Applied more z-pozy and then sprayed with SV. No sealer coat. So far so good.
Joe Beaver
Maker of Sawdust
PostPosted: Wed Aug 28, 2013 2:38 am
Joe, it's not strictly relevant to the original post, but there's an old thread here: viewtopic.php?f=10101&t=29797 that discusses adhesion problems with KTM-SV when used over shellac seal coats.
I've used KTM-SV on my last three guitars, and have been pretty happy with it since the adhesion issues were solved.
Pete
PostPosted: Wed Aug 28, 2013 11:09 am
First name: Rodger
Last Name: Knox
City: Baltimore
Zip/Postal Code: 21234
I use shellac seal coats frequently. If you sand through anywhere, and don't sand it all off, you can get "witness lines".
I've left the seal cost intact and also sanded them all off, it's just a slightly different effect, and I think "better" may depend on the piece of wood.
I think the correct term is refractive index, that's what causes the grain to pop differently.
PostPosted: Wed Aug 28, 2013 11:15 am
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
Typically, shellac is not a great sealer for use under water base finishes due to the fact that shellac has poor resistance to water.
Brian
PostPosted: Wed Aug 28, 2013 12:18 pm
Last Name: Beaver
City: Lake Forest
I take from this that shellac was a bad idea. I'm hoping that SV over epoxy remains stable.
Joe Beaver
Maker of Sawdust
PostPosted: Wed Aug 28, 2013 12:29 pm
Last Name: Beaver
City: Lake Forest
Pete,
What was your solution to resolve the bonding issues?
Joe Beaver
Maker of Sawdust
PostPosted: Wed Aug 28, 2013 6:47 pm
Joe Beaver wrote:
Pete, what was your solution to resolve the bonding issues?
Joe, I managed to find a supplier of the two-part Ilva sealer Randy Muth recommended in the thread I referenced. Randy provided me with the following information and, although I wasn't able to find the exact products locally, I did find a very similar Ilva barrier coat product and a compatible accelerator.
"I get this stuff from Camger in Massachusetts. It's called ILVA Universal Polyurethane Barrier Coat. The overall product code is TF-25. Each component also has codes as follows:
Polyurethane Barrier Coat: TF-25
Accelerator: TV-19
Thinner: TZ-35"
After reviewing that old thread, I note that Rolfe Gerhardt reports no problems using Zinsser Sealcoat as a sealer and tie coat under KTM-SV. I couldn't find a supplier in Australia and went for the Ilva product instead.
Pete
PostPosted: Wed Aug 28, 2013 6:53 pm
Last Name: Beaver
City: Lake Forest
Thank you Pete, I'll make a note of it.
One last question, you spray it on bare wood and over epoxy pore filler?
Joe Beaver
Maker of Sawdust
PostPosted: Wed Aug 28, 2013 7:18 pm
For the back, sides and neck, I apply it over epoxy. For the soundboard, it's applied over bare wood. I've sprayed it so far, but I believe a foam brush does as good a job, with the added advantage that you're not filling the air with the stuff. Any product with the word "isocyanate" in the product description makes me nervous; I'd definitely use the Zinsser Sealcoat if I could find a source for it.
Pete
PostPosted: Wed Aug 28, 2013 7:46 pm
Last Name: Beaver
City: Lake Forest
Thanks again. I think I'll give it a try
Joe Beaver
Maker of Sawdust
Users browsing this forum: rbuddy and 16 guests
