It is currently Sun May 24, 2026 5:24 am
PostPosted: Thu Aug 07, 2025 9:13 am
First name: Peter
Last Name: Tourin
City: New London
Zip/Postal Code: 03257
Iʻm working on my first guitar - a steel string OM cutaway - so Iʻm a total plucked string newbie. Iʻve been a bowed string builder for over 30 years, with about 120 viola da gamba builds and a few cellos. So I have lots of experience and a good collection of hand and tools. Iʻm finding that many things about guitar making are completely familier, but certain things are totally different - primarily binding/purfling/inlay and action setup.
At this point I have my assembled body and Iʻm about to start with edge binding. The body is spruce/rosewood. I have some plain koa/BWB for the binding. I have some BWB/Zipflex/BWB for the trim. The big question: what setup am I going to use for routing, since I may or may not make more guitars and I therefore donʻt want to invest in a big expensive routing setup. Not totally opposed, but Iʻd like to be frugal if I can. Also, part of this build is my wish to get into abalone trim work, as Iʻve always loved abalone, esp blue, and I have a variety of projects for which I want to have some abalone experience.
Hereʻs what I have available...
I have a Dremel, the StewMac tiltable router router base and the edge guide. Iʻm hesitant to use this with the guitar in a clamp base, because itʻs hard to keep the router vertical, from what little I can see in a few test runs.
I have a big Bosch router but not a smaller laminate trimmer.
I have a nearby makerspace with a nice router table - probably a few lam trimmers as well, tho I havenʻt looked yet.
I have the usual violinmakers purfling groove tools, though I mostly used a Dremel setup to cut purfling grooves on the bowed string instruments.
I donʻt have the set of 1" router bit and all the bearings, though I can get a set if need be.
So - Iʻm up for hearing any advice and suggestions. If youʻve used the Dremel/StewMac base and you think it can be done nicely with practice, Iʻd like to hear about it. Likewise, if you think that path is hopeless for accuracy, Iʻd like to know. If you have a suggestion for a DIY router jig that wonʻt totally break the bank and will work well enough for a guitar or three, Iʻm interested.
Thanks for any helpful thoughts - Iʻve wanted to try a guitar for a long time, and itʻs quite a lot of fun so far...
These users thanked the author ptourin for the post: Kbore (Thu Aug 07, 2025 9:33 am)
PostPosted: Thu Aug 07, 2025 9:31 am
First name: Karl
Last Name: Borum
Zip/Postal Code: 63303
Peter, welcome to the OLF. That is beautiful ornamentation on that instrument.
My first binding job, I spent an inordinate amount of time creating guides, holders, followers and the like for my newly purchased Colt Trim router to cut a binding channel. Practicing with smooth bit stock, router off, I had a 0% success rate of not tipping the router at some point around the perimeter. I never found a way to cut the channel with complete confidence and accuracy without a router mounted in a fixture. The domed top had a lot to do with it.
I finally bought the router fixture and the bits. I never had a mishap (not counting launching a body off the bench and across the room- with a believe it or not, smooth landing on an upholstered bar chair.
Others here will likely have better suggestions for a one-off binding channel solution; I've seen videos of it being done. I just did not have the chops to do it by hand.
Measure Twice,
Karl Borum
These users thanked the author Kbore for the post: ptourin (Thu Aug 07, 2025 9:59 am)
PostPosted: Thu Aug 07, 2025 10:05 am
First name: Peter
Last Name: Tourin
City: New London
Karl - youʻve hit my main concern. My top is slightly arched, my back more so. In addition, itʻs a Florentine cutaway, and my edge sanding to get the arched back got a bit irregular at the cutaway - so itʻs not the most simple shape to follow.
These users thanked the author ptourin for the post: Kbore (Fri Aug 08, 2025 4:05 pm)
PostPosted: Thu Aug 07, 2025 10:22 am
Last Name: Kincheloe
Personally I find it unthinkable to allow a vicious high speed router near a mostly-finished soundbox made of expensive wood. Especially after seeing the many disasters posted to this forum over the years. Gramil and chisel for me. Unfortunately the gramil was sold by LMI so may no longer be available anywhere, but your violin purfling tools are probably about the same thing. I also use a rectangular needle file with safe edge for refinement, and riffler file for the waist.
I've only done one with shell purfling, but it was surprisingly easy. I used abalam, some straight and some curved strips to minimize chance of visible gaps at the breaks. The only tricky part is getting the channel depth just right so there are no low spots, but you don't sand through the top laminate layer either. But you can scrape at the bottom of the channel if there are high spots, and add paper underneath the shell to raise up low spots. An x-acto blade sharpened to a chisel point is very handy for getting shell pieces back out of the slot and scraping the channel.
P.S. I'd love to see a viola da gamba build process. I've considered making one, or some similar fretted bowed instrument. I'm amazed at how thin that fingerboard is at the end... is the thickness tapered, or the whole cantilevered portion that thin?
These users thanked the author DennisK for the post: ptourin (Thu Aug 07, 2025 3:00 pm)
PostPosted: Thu Aug 07, 2025 12:42 pm
Last Name: Parker
City: Charleston
State: West Virginia
Zip/Postal Code: 25314
If you don't want to invest in a router setup, you can use your transferable skills and just do it by hand, as Dennis does. A purfling cutter should be capable of doing the marking; then you chisel out the waste by hand. I've done it once all by hand. I prefer using routers, but I do have a fancy schmancy tower setup to make it work out well, and it wasn't cheap.
A great tip: When fitting, slightly round over the edge of the binding that fits into the inside corner of the binding ledge. A pointy edge on that edge of the binding is counterproductive, and can make it not fit right, whereas rounding that edge over gets the fit of the inside corner out of the equation, leaving the fit to the mating of the faces, not that corner. I hope that makes sense.
These users thanked the author doncaparker for the post (total 2): Kbore (Thu Aug 07, 2025 6:40 pm) • ptourin (Thu Aug 07, 2025 3:02 pm)
PostPosted: Thu Aug 07, 2025 1:15 pm
City: Tyler
Peter, you asked about the dremel and stewmac precision guide. My first guitars were done with the same. It is doable but frankly, I found the dremel to be under powered for the task. Each guitar I used it on had chip outs on the sides. Some quite ugly and required a lot of fixing (and the fixes weren’t great).
I would recommend the above mentioned approach- dremel and chisels the files. I use these when binding headstocks to this day. Slow but actually kindle of relaxing. With your skills in the images I’m sure you’ll ace it.
These users thanked the author Glen H for the post: ptourin (Thu Aug 07, 2025 3:03 pm)
PostPosted: Thu Aug 07, 2025 1:23 pm
First name: David
City: Napa
Zip/Postal Code: 94558
Unless you have really good hand and eye coordination and have a lot of experience with intricate chisel work, do not do this by chisel. Invest in a laminate trimmer and used one can be had for about $50 on FB marketplace or CL. You also don't need the entire set of luthier bearings. Figure out which ones and only order about 5 pieces.
These users thanked the author dofthesea for the post: ptourin (Thu Aug 07, 2025 3:09 pm)
PostPosted: Thu Aug 07, 2025 2:04 pm
First name: Freeman
Last Name: Keller
A decent laminate trimmer can be had for way less than a hundred bucks, a Bosch Colt is slightly above. Buy the SM bit and bearings. Tape a couple of wedges to the router base and carefully orient the router to keep if vertical as you go around the body.
I did a half dozen or so "flat top" guitars before I finally broke down and bought a floating router setup to do tops with more arch.
These users thanked the author Freeman for the post: ptourin (Thu Aug 07, 2025 3:04 pm)
PostPosted: Thu Aug 07, 2025 2:41 pm
First name: Jay
Last Name: De Rocher
City: Bothell
State: Washington
Since Peter has a Dremel and would like to avoid a big investment at this point, does anyone here have experience with the StewMac Binding Router Guide?
https://www.stewmac.com/luthier-tools-and-supplies/tools-by-job/tools-for-binding/binding-router-guide?queryid=0f9ecf3af9471301bfa841967677747e
It fits a Dremel, needs only one bit, and if keeping the cost as low as possible is a priority, there are router guides of the same design available for less than half the price.
These users thanked the author J De Rocher for the post: Kbore (Thu Aug 07, 2025 6:42 pm)
PostPosted: Thu Aug 07, 2025 3:24 pm
First name: Peter
Last Name: Tourin
City: New London
Dennis - gamba tops are graduated like violin tops are. They tend to be thin along the edges and thicker towards the center, with a more or less oval thick area centering where the bridge sits - though Iʻve measured lots of exceptions to this!! Back in the day, we measured many museum instrument tops using a homebuilt thickness gauge that used a small magnet and a Hall effect transducer. It was nothing fancy but it worked well.
The bass bar is sprung much like guitar back braces - the bar should push the top up around the bridge area - then the down pressure of strings on the bridge pushes it back down again - these should more or less balance out. The forces involved are relatively small, nothing like on a violin or cello - thin gut strings.
The viol family of instruments were usually played by amateurs in small settings - wealthy merchant families, courtiers - so they varied a lot in shapes and they tended to have a lot of decoration. The violin family of instruments tended to be played by professional musicians - the guys those wealthy families hired to play for evening entertainments, dances and so on. So they tended to be less fancy and less highly decorated. This is a serious generalization, but it stayed fairly true for 3 centuries across many European countries. When tastes changed to larger-scale performances - operas, orchestras, oratorios - the viols fell out of favor as they were quiet chamber music instruments, and the violin family took over.
PostPosted: Thu Aug 07, 2025 4:19 pm
First name: Freeman
Last Name: Keller
I bought one when I built my F5 mandolin. It worked with a lot of care and clean up, and might be the best way to do the scrolls (altho I would consider making a gramil if I ever did another mando)
I have never used it after that, I went back to the wedges on the bottom of my laminate trimmer and then built a floater to do archtops.
These users thanked the author Freeman for the post (total 3): Kbore (Thu Aug 07, 2025 6:43 pm) • J De Rocher (Thu Aug 07, 2025 5:37 pm) • ptourin (Thu Aug 07, 2025 5:37 pm)
PostPosted: Fri Aug 08, 2025 12:20 pm
I did my first four archtops with one and it worked pretty well with a lot of care and concentration and many small bites and adjustments. Probably six or eight trips around both the top and back. Bought the Stewmac jig and bearings after that which made the process a lot easier and less nerve wracking.
These users thanked the author Darrel Friesen for the post (total 3): J De Rocher (Fri Aug 08, 2025 9:59 pm) • Kbore (Fri Aug 08, 2025 4:05 pm) • ptourin (Fri Aug 08, 2025 2:32 pm)
PostPosted: Sun Aug 10, 2025 4:20 pm
First name: Peter
Last Name: Tourin
City: New London
Well, I can see already that using a Dremel is a bit of a losing battle - Iʻll use it for inlay. I picked up a Bosch Colt cheap and Iʻm trying to decide what to do with it. Pretty inclined towards a variant of the KMG binding channel routing system:
https://www.harvestmoonguitars.com/kenn ... chine.html
Itʻs inexpensive and easy to build, lets you set depth and width of cut without the big cutter and bearings, and errors make the cut too shallow instead of trashing things. If it turns out to work well, a bit of metal fabrication could give you good depth and width adjustment.
Have any of you tried it or similar "router table" type systems?
PostPosted: Sun Aug 10, 2025 5:44 pm
Last Name: Gramann
City: Fredericksburg
State: VA
Zip/Postal Code: 22408
That’s a beautiful system. It ought to work great. I wish I had thought of it. I haven’t used that, but I have cut channels on well over 100 guitars freehand with a binding bit, done several on the Elevate jig, and some on the StewMac jig. All of the methods work. Like the step in the KMG system, all of these methods have a donut or a rise on the router base so that the router is guided by the edge of the plate and doesn’t get tilted by the doming of the plate.
One thing the video doesn’t show: to prevent tearout (unfortunately, not all of it), rout in 4 passes from the wide point of each bout to the narrow. Half of the passes will have a climbing cut. That can be awkward, but it keeps the router bit from cutting under the grain and ripping it out.
These users thanked the author bobgramann for the post: ptourin (Sun Aug 10, 2025 5:57 pm)
PostPosted: Sun Aug 10, 2025 6:15 pm
First name: Peter
Last Name: Tourin
City: New London
You know, Bob, Iʻve been thinking about tear-out. This may seem completely silly, but I donʻt see why not use a gramil to score right at the inside edge of the cut. That would take no time at all; all the time in doing the job by hand is getting the depth right and chiseling the flat. Iʻd think thatʻd get rid of the tear-out problem entirely. Itʻd be just one go-round at the inside edge of the purfling groove, Iʻd think. I donʻt think that you care about tear-out at the inside of the binding groove (assuming that you do it first) - you just go right over that edge when you do the purfling groove. You could also clean it up with a tiny bit of sanding afterwards. I havenʻt thought this all out too well yet since Iʻve never done it.
Iʻll have a plain koa binding (rosewood sides), and Iʻll have a rather wide purfling groove - the widest Zipflex abalone with BWB wood on both sides of it. Iʻm guessing at first thought that Iʻll Titebond the koa and the 2 BWB strips with a piece of Teflon in place of the Zipflex - then do the Zipflex later with CA. Iʻm assuming Iʻll bend the binding and the 2 BWBʻs first, then glue and tape them. Am I missing anything obvious here? We never do inlay like this on bowed strings - itʻs pretty much just either a single or a double row of purfling so itʻs much easier.
Our viola da gamba building had other decorative challenges as you can see in my photos up at the top of the post - the fingerboard is quartered spruce with a top veneer, and the geometric purfling work is done after the veneer is in place. The rosette is done before the top is glued on, of course. The VdG tradition had LOTS of very fancy decorative work since the instruments were owned mostly by rich amateur players.
PostPosted: Sun Aug 10, 2025 7:16 pm
Last Name: Gramann
State: VA
I would have liked to believe that prescoring the cut with the gramil would prevent tearout. I’ve done it and and can testify that it doesn’t always. The problem is routing across the wood fibers; the bit can get between the fibers and force a split well beyond the radius of the bit. I wish I could say I’ve never seen it happen, but I have some souvenir tops and backs with chunks out of them. The same thing happens with woods like Osage Orange on the sides. On those, I take shallow cuts initially, working up to full depth in three passes. For, the purfling ledge, inside the bindings, the top is supported by the wood that’s left behind under it. I’ve never had problems there.
When I’ve cut my binding channels with a chisel, I use the gramil to mark and score the edges of the channel and then remove the interior in small chunks with the chisel like you would mortise for a door hinge. It takes a long time.
Be careful with the CA on a spruce top. It can soak into the grain and go places you’d rather it hadn’t. Sometimes it can change the top color. A good shellac seal can usually prevent that. I keep the CA away from my spruce.
Your viola de gamba work above is beautiful.
These users thanked the author bobgramann for the post: ptourin (Mon Aug 11, 2025 7:57 am)
PostPosted: Mon Aug 11, 2025 8:06 am
First name: Peter
Last Name: Tourin
City: New London
Thanks Bob, thatʻs all very interesting and a bit sobering - Iʻve been watching peopleʻs posts on their favorite jigs, showing them just flying around the guitar at slightly subsonic speeds <g>... My main things about doing the channels by hand, of course, are time and accuracy - Iʻm not sure just how close the channels have to be when youʻre doing prefab abalone like Zipflex. I am intending to do multiple passes on the binding channel. And I just ran into Heshʻs posts about runout issues with routers, a few days AFTER I bought a used Bosch - oh well, I suppose itʻs the way we learn...
I am intending on a shellac seal, was considering whether I was going to seal the whole instrument or just the edge area - and again, the newbie factor: I bought shellac that turned out to be waxed, so I ordered another can. My old shop is in VT 2 hours away - we have shellac flakes there and I could have gone up and fetched, but cans are the lazy manʻs solution...
What would you use to glue Zipflex if you werenʻt going to use CA? I hadnʻt considered this as every post I look at does at least the abalone with CA. Iʻve been assuming Iʻd Titebond my wood binding, BWB purfling and a teflon strip, then do the Zipflex after.
PostPosted: Mon Aug 11, 2025 8:31 am
Last Name: Gramann
State: VA
I can’t answer about the Zipflex. I’ve never used it. The only pearl I’ve ever inlaid was on the headstock and fingerboard where CA was useful and no problem. That’s the only place where I use CA other than for filling gaps discovered into the finishing process. The better channels and ledges you cut, the better your binding job will be. Inaccurately cut ledges will show with variable thickness bindings after you scrape them even with the sides. The device you linked to ought to cut nice ledges. Practice on scrap wood until you have it figured out. You won’t know if your Bosch will do the job for you until you try it—you might have won a good one. I don’t know if it’s just a coincidence that Bosch makes the Dremel. I have a large (EVS-1617) Bosch router that is excellent. It would work in a router table with the device you showed but with any other method would be way too big.
These users thanked the author bobgramann for the post: ptourin (Mon Aug 11, 2025 10:30 am)
PostPosted: Mon Aug 11, 2025 10:32 am
First name: Peter
Last Name: Tourin
City: New London
I also have a big Bosch router/plunge router that I like - I bought the Colt when I was thinking of a hand-held binding jig - weʻll see how it works. I just found that Precise no longer makes a collet for the Colt - they cite "compatibility issues". Iʻll do a separate post to see if there are other good collets that people have tried.
PostPosted: Mon Aug 11, 2025 11:41 am
Last Name: Gramann
State: VA
You can get runout in a router at least 3 ways. The collet can be irregular. The shaft can be bent or bored off-center. And/or the bearing can be sloppy or improperly supported (that’s what’s wrong with my Dremel). A better collet can fix only one of these. If you have the bigger Bosch router, you can use that in the table with the KMG-like device and expect good results.
PostPosted: Mon Aug 11, 2025 2:52 pm
First name: Jay
City: Bothell
State: Washington
Maybe I'm lucky, but the two Bosh Colts I've been using for years have worked perfectly for routing binding and purfling ledges, rosettes, and saddle slots. The saddle slot widths come out right on the mark. I use a PreciseBits collet so maybe that helps.
Maybe I've also been lucky regarding tear out when routing binding/purfling ledges, but it hasn't happened (so far at least) on a fairly wide variety of woods. I use the Colt in a simple tower and the StewMac cutter and bearings. I always route downhill from the tips of the bouts. I do the purfling ledge first in one pass and then the binding ledge in one pass and it always works.
These users thanked the author J De Rocher for the post: ptourin (Mon Aug 11, 2025 3:20 pm)
PostPosted: Mon Aug 11, 2025 3:25 pm
First name: Peter
Last Name: Tourin
City: New London
I hope I have the same luck Jay! I got the router today - itʻs a new but out of the box and was cheap. So far looks OK - no end play, the adjustments work about as badly as one would expect <g>... Iʻm waiting for a bit - all my bits are up in my old shop in VT; I left a lot of tools and equipment for the guys who used to work for me. Hoping itʻll be OK.
Iʻm going to use ChrystaLacʻs pore filler/sealer/finish products, and they let me know that their pore filler and sealer will bond over unwaxed shellac.
LATER: Iʻve been building a router jig thatʻs a slight modification of the KMG jig. I seem to have done OK with the Bosch laminate trimmer - Iʻve only done a bit of testing but havenʻt seen a lot of runout or end play. I should know more in a few days. Iʻm posting a few crude photos of my prototype - I already know things Iʻd do differently. One problem is that itʻs big enough so it wonʻt completely rout the inside of the cutaway - Iʻll have to do a few inches by hand.
Users browsing this forum: No registered users and 95 guests
