It is currently Sat Jul 26, 2025 8:45 pm
 Post subject: Sycamore back bracing
PostPosted: Thu Nov 15, 2018 12:25 pm
Last Name: Spector
City: ORANGE
Zip/Postal Code: 77632
No. 13 is going to be Sycamore back and sides from a neighbor's tree. Just wondering which wood some of you might prefer for bracing on the back. It will have a spruce top and I use spruce for top braces. I have plenty of maple and walnut, maybe one of those?
PostPosted: Thu Nov 15, 2018 12:43 pm
Last Name: Spector
City: ORANGE
Or just more sycamore for the braces?
PostPosted: Thu Nov 15, 2018 1:01 pm
First name: Danny
Last Name: Vincent
I like Spruce! Others can work. Spruce has the stiffest strength to weight ratio..... typically.
PostPosted: Thu Nov 15, 2018 3:18 pm
If you want a stiff and heavier reflective back (which is not a bad way to go on that size guitar) maple might not be a bad choice. I think it would look better than walnut. If your sycamore is spalted I would avoid it for braces.
PostPosted: Thu Nov 15, 2018 5:23 pm
Last Name: Spector
City: ORANGE
I'll avoid using any "spalted" wood for braces since the spalting is usually caused by fungi or decay, even though it looks cool. I just broke one of the spalted sycamore sides I had prepared, after bending it. I was flexing it before putting it into the mold and the upper bout broke clean across. That wasn't cool...but I didn't get mad, since I have more and I found out at an early stage that it was faulty.
PostPosted: Fri Nov 16, 2018 3:21 am
First name: Oris
Last Name: Morton
City: Franklinton
That’s going to be a nice back. I’d use spruce braces
PostPosted: Fri Nov 16, 2018 8:03 am
First name: Ernest
Last Name: Kleinman
City: Guthrie
Zip/Postal Code: 73044
Check out the density of your spruce . They are not created equal. Sitka has the stiffest weight to density ratio IMHO
