It is currently Mon Jul 21, 2025 11:33 pm
 Post subject: enlarging holes
PostPosted: Sat Feb 24, 2018 3:12 pm
First name: Conor
Last Name: Searl
City: Duncan
State: British Columbia
Zip/Postal Code: V9L 2E5
Any tips on enlarging pre-existing holes without losing the centre? I have to make some tuner holes bigger, and some bridge stud holes bigger. I've got a tuning hole reamer, and 11mm drill bit for the studs, but I'm worried when I use them I may shift the centre of the holes. I don't have a drill press, so I guess I'm also worried about coming at the holes straight.
 Post subject: Re: enlarging holes
PostPosted: Sat Feb 24, 2018 3:44 pm
First name: Stephen
Last Name: Foss
State: Colorado
Conner,
Would a 'step drill' do the trick?
https://www.amazon.com/Neiko-10193A-Tit ... +drill+bit
PostPosted: Sat Feb 24, 2018 6:22 pm
a unibit (step drill bit) will allow you to get to the right diameter as a starter...you will most likely have to change to a standard bit once you get there (e.g. the odds of the last diameter on the bit being the diameter you desire are low)
also, you mention a metric size...never seen a unibit in metric, though one would think they make one...
as a side note: when drilling through thick steel without a drill press a unibit rules over standard twist bits...I used to easily burn up a standard bit per use when modifying barn door flat tracks to be the exact right length for the intended use...once I switched to a unibit...well, I'm still using that same bit from a couple of years ago!
PostPosted: Sat Feb 24, 2018 7:00 pm
First name: Conor
Last Name: Searl
City: Duncan
That step bit looks perfect. Thanks guys.
PostPosted: Sat Feb 24, 2018 7:55 pm
City: Lawrence
Zip/Postal Code: 66047
https://www.amazon.com/OCGIG-Spiral-Gro ... dpSrc=srch
PostPosted: Sat Feb 24, 2018 8:19 pm
Last Name: McDonald
City: Okanagan Centre
Zip/Postal Code: V4V2H6
Couple of other thoughts;
1.Make a drill guide from a 1” or thicker piece of material and clamp in place. If using a forstner bit, 3/8” thick.
Or
2. Plug the holes and remark center.
B
Online
Last Name: Parker
City: Charleston
State: West Virginia
Zip/Postal Code: 25314
You can also glue a stubby dowel of the right diameter into the hole, then redrill.
PostPosted: Sat Feb 24, 2018 8:25 pm
First name: Freeman
Last Name: Keller
I bought the very expensive end pin reamer for installing pickups because of hearing horror stories of people trying to do it with twist drills. One problem with uni-bits is that each step isn't very long - you might have problems with something like an end block or a headstock.
PostPosted: Sat Feb 24, 2018 9:56 pm
If you have a tuner hole reamer that may not be a bad way to go. To ream holes slightly larger I've used a twist drill bit in an electric drill run backwards (less chance of chip out).
Here's is something I found on you tube (which I have also done):
www.youtube.com/watch?v=oy55TU5OlLU
PostPosted: Sun Feb 25, 2018 6:27 am
First name: Willard
Last Name: Guthrie
City: Cumberland
State: Maryland 21502
Zip/Postal Code: 21502
Country: United State
We use a series of chucked reamers in a drill press, or a step drill followed with a chucked, straight fluted reamer for these sorts of jobs.
Most chucking, straight-fluted reamers have a generous chamfer at the tip, which is there to center the tool on the existing hole. While opening a tuner hole from 1/4" to 0.340", 0.348", or 0.363" is quickly done in a single step with a piloted reamer, opening a hole to final size without a definite purpose tool available is better done with a couple reamers or a step drill/reamer combination than with twist drills which are not modified for use in wood or other softer materials. A step drill can speed up the process, but usually cannot cut deeply enough at the final diameter to complete the hole without reaming.
A full set of HSS reamers from 1/16" to 1/2" in 1/64th inch increments, plus 6mm, 9mm, 10mm, 11mm, and 13mm should run about $220 from Ebay in import quality, and are some of the most useful tools in the shop.
- Beth Brower
PostPosted: Tue Feb 27, 2018 1:23 pm
First name: peter
Last Name: havriluk
City: granby
State: ct
Zip/Postal Code: 06035
A set of numbered (or lettered, depending on how big the hole is) drills may offer some help. Idea is to drill holes one size larger than the last drill bit and walk up to the end size in many drilling steps. Chipping is also less of a problem that way. And it's hard to over-do a hole, like I heard somebody did once with a step drill when he didn't pay enough attention to what he was doing.
I've found step drills really useful for making concentric holes in thin material; never tried to use one to pilot a hole in thicker stuff.
Peter Havriluk
PostPosted: Tue Feb 27, 2018 10:18 pm
First name: Willard
Last Name: Guthrie
City: Cumberland
Step drills work nicely in thicker materials, and have the advantage of shearing finishes nearly as cleanly as a fluted reamer, so no need to worry about lifting the lacquer with a twist drill. Also useful on jack replacement, such as converting the G&L jack to a standard 1/4" Switchcraft mono and mounting plate. For acoustic jack installs, a 1/8"-1/2" step drill gets the hole opened to correct diameter, and the job is finished with a chucked, straight flute reamer of the correct size. While the StewMac tool is what we usually use (the higher cost is made up for over time with reduced labor), a step drill and a 15/32" reamer is about half the cost of a special purpose tool, and works just as well.
- Beth Brower
PostPosted: Wed Feb 28, 2018 3:39 am
Last Name: Howell
City: Atlanta
State: Ga
I have had success drilling straight holes by using long drills and /or extension, when drill press was not convenient. But setting up a flat reference surface somewhere is necessary and often the key.
PostPosted: Wed Feb 28, 2018 6:28 pm
First name: Dan
Last Name: Savage
City: Trabuco Canyon
Zip/Postal Code: 92679
The easiest and cheapest method is to use a model airplane prop reamer. These are usually available for less than $20 at your local hobby store, or you can order them online from outfits like Tower Hobbies.
This is the one I use. (Great Planes Precision Prop Reamer Metric - $14.99)
This will enlarge the holes in the head stock without changing the hole's center. These are also available in SAE sizes.
These users thanked the author DanSavage for the post: Colin North (Thu Mar 01, 2018 7:50 am)
PostPosted: Thu Mar 01, 2018 4:16 pm
https://www.wikihow.com/Ream-a-Hole
Andy
Users browsing this forum: doncaparker and 17 guests
