It is currently Sun Jul 20, 2025 4:21 pm
PostPosted: Thu May 25, 2017 7:30 am
Last Name: Imbler
State: KS
Zip/Postal Code: 67204
I'm building my first steel string (normally build classicals), and I have a big stock of very nicely quartered Engelmann Spruce brace wood. The plans call for Sitka top bracing. If I used the Engelmann, how much would I need to increase the brace dimensions (if at all)? Since this is my first, I can't really brace by stiffness because I have nothing to compare to,
Thanks for any help,
PostPosted: Thu May 25, 2017 7:39 am
Last Name: Collins
City: Argyle
State: New York
Zip/Postal Code: 12809
Use the wood you have.
It may be more flexible!
It may be lighter in weight ,which could help with loudness & tone.
Mike Collins
These users thanked the author Mike Collins for the post: Imbler (Thu May 25, 2017 8:43 am)
PostPosted: Thu May 25, 2017 9:00 am
Last Name: Cox
It depends on how stiff it is compared to average book values.
Say average engleman has a modulus of elasticity that's 15% softer than average sitka... Since stiffness goes with the cube of beam depth - making up 15% stiffness only requires something like 5% more thickness... Say your top bracing sitka is 16mm - engleman would only need 0.8mm more depth to be back at the same stiffness..
These users thanked the author truckjohn for the post (total 3): ChuckH (Tue May 30, 2017 10:52 pm) • chlng (Tue May 30, 2017 12:57 am) • Imbler (Thu May 25, 2017 9:13 am)
PostPosted: Thu May 25, 2017 10:05 am
If you look at compare average values listed for the spruces, Engelmann has about 90% of the elastic strength of Sitka. If you have a large stock to choose from, you might do a simple test to find out which are the stiffer pieces and use them as you would Sitka. Most plans list brace sizes on the conservative side, so even a less stiff piece will usually work.
PostPosted: Thu May 25, 2017 10:52 am
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Zip/Postal Code: 64081
I would chose the sitka for a ss gtr..I spent many yrs in BC and englemann spruce comes in light, med , and hvy densities depending on where it/s grown on the west coast.. If your going to use e. spruce test it to see how stiff it is , and then factor the difference. and add that height to your bracing e.g. if the plans for sitka brace height is 12mm and your englemann brace is 25% weaker I would make my e. brace 15mm high. This is just an example, your experiments might dictate otherwise
These users thanked the author ernie for the post: Imbler (Thu May 25, 2017 11:29 am)
PostPosted: Thu May 25, 2017 1:32 pm
If you look on the bright side, most plans are over built anyway, so if you use the Englemann and stick to the plan, win win. :D
These users thanked the author jfmckenna for the post: Imbler (Thu May 25, 2017 1:40 pm)
PostPosted: Thu May 25, 2017 3:11 pm
Last Name: Arnold
City: Newport
Zip/Postal Code: 37821
Truckjohn is correct. Stiffness is proportional to the cube of the height. Adding 25% to the height will increase the stiffness by 95%. If you want to make the braces wider, then stiffness is directly proportional. In other words, if you want to increase the stiffness by 25%, increase the width by 25%.
I built guitars all through the 1980's with Engelmann bracing, and I made the braces the same dimension as a stock Martin or Gibson, or very slightly taller (no more than 5%). Those guitars have survived just fine.
These users thanked the author John Arnold for the post: Imbler (Thu May 25, 2017 4:43 pm)
Users browsing this forum: Kbore and 18 guests
