It is currently Sun Jul 20, 2025 1:44 am
Post new topic Reply to topic  [ 30 posts ]  Go to page Previous  1, 2
PostPosted: Tue May 16, 2017 8:37 pm
First name: Nils
Last Name: Johnson
City: Boston
State: Massachusetts
For binding pieces made by cutting sides down to size, I do the clothes pin technique.
If I have a flatsawn board, I use a fire-hose and an air compressor to make a sandwich. Then I slice it on the table saw.
Here's a shot of the sandwich to give the idea. Image
PostPosted: Wed May 17, 2017 3:00 pm
State: West Somerset
Country: UK
I happen to be at that stage with a build. It is a cutaway so I am going to need fairly high temperatures to do the bend. I remember the stink of CA when it is heated so I thought I would try something different. I am trying glue known as Cascamite in the UK. It has had various names at different times. A resin that you mix with water. It is supposed to be very resistant to pretty much anything when set.
I have also tried the multiple clip approach and the compression jig as above. It needs a few hours to set so I'll report back later.
I wondered if anyone else had tried it?
I am only doing this because I wanted to use matching mahogany in the bindings to the rosette. Much easier to buy in if you can.
PostPosted: Wed May 17, 2017 3:20 pm
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
At a guitar seminar last year, I was talking with Marc Beneteau about purfling glue ups, and he said that he used the Circa resin glue. Water and heat resistant enough for guitar use.
He also said that he strains the glue after it is mixed.
Alex
These users thanked the author Alex Kleon for the post: James Orr (Wed May 24, 2017 7:51 pm)
PostPosted: Fri May 19, 2017 7:00 pm
I just bent some snakewood binding with a white/black/white (.020,020,0200) using titebond 3 (waterproof)
It worked perfectly-no delamination .
These users thanked the author Brad Goodman for the post: Pmaj7 (Wed May 24, 2017 10:59 am)
PostPosted: Wed May 24, 2017 8:52 am
Country: UK
Well Cascamite worked fine, it stood up to a pretty high temperature. The pufling itself was delaminating while the cascamite held firm.
Shame I couldn't persuade the mahogany into the tight cutaway bend!
Using multiple clips to clamp worked but gave a slightly uneven result. I did much better with a simple squeeze jig.
