It is currently Tue May 26, 2026 7:02 pm
PostPosted: Fri May 22, 2015 7:43 pm
What is your preferred method for staining Mohagany to match EIR?
See photo below for a representation of what I'm after.
Does it affect volume or tone?
Do most Luthiers just not worry about it?
-j
PostPosted: Fri May 22, 2015 8:08 pm
First name: Jay
Last Name: De Rocher
City: Bothell
State: Washington
Maybe someone somewhere has done this, but I've never heard of anyone trying to make mahogany look like EIR. Why do you want to try to do that?
PostPosted: Fri May 22, 2015 8:12 pm
I'm not trying to fool anyone, I just like the idea of the whole back the same color. You may not have heard of it but there's a photo showing someone has done it. I like it and it's purely a matter of personal taste.
-j
PostPosted: Fri May 22, 2015 8:21 pm
First name: Cal
Last Name: Maier
City: Crossfield
State: AB
When spraying nitro I colour the lacquer using NGR (non grain raising) stains when matching the colour of the back and sides. The stain in the photo would probably be Dark walnut. The stain doesn't affect volume or tone. The thing that would affect volume and tone the most is the thickness and amount of finish applied to the guitar, I think most builders try to use finishes that do not affect tone to a great degree.
Cal
PostPosted: Fri May 22, 2015 8:29 pm
First name: Jay
City: Bothell
State: Washington
-j
Yea, there are lots of things I haven't heard of. My point was just that it seems like an unusual thing to do and I was just curious why you want to do it. Do you like the darker color of rosewood but prefer the sound of mahogany, for example?
PostPosted: Fri May 22, 2015 8:36 pm
I like that look. Pretty nice.
PostPosted: Fri May 22, 2015 8:39 pm
J De Rocher wrote:
-j
My back and ribs are EIR and my neck is Mohagany. I just prefer the whole back to be a uniform color and darkening Mohagany is much easier than making EIR lighter. I like both wood's natural color but I lean a bit toward liking rosewood more. I feel like a giant jumble of colors is distracting so I want to minimize them as much as possible.
Now I'm wondering how I can make a Mohagany stain?
PostPosted: Fri May 22, 2015 8:53 pm
First name: Jay
City: Bothell
State: Washington
Now it makes sense. Sorry, I didn't understand that you were wanting to match the color of a mahogany neck to EIR back and sides. That wasn't clear from the original post, at least to me. [uncle] Someone here is bound to have your answer.
PostPosted: Fri May 22, 2015 9:02 pm
First name: Aaron
Last Name: Hix
City: Chatsworth
State: Georgia
Zip/Postal Code: 30705
Minwax makes an oil based stain color called "Jacobean", which I have used on mahogany necks, that is near identical to the color of the neck in your picture. I like dark necks to match dark back and sides as well.
Guitar Maker and Purveyor of the World's Finest Tonewoods
http://www.aaronhixguitars.com/
http://stores.ebay.com/A-Hix-Tonewood-a ... r-Supplies
PostPosted: Fri May 22, 2015 9:11 pm
No worries, I may not be the best Writer so it may have been unclear.
PostPosted: Fri May 22, 2015 9:12 pm
I'd love to see a photo of this stain in action.
PostPosted: Sat May 23, 2015 7:46 am
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
I use Behlens Solar-lux dye satin to match mahogany to EIR. I use a blend of Hickory, black & med red mahogany to get a good match.
Brian
PostPosted: Sat May 23, 2015 11:48 am
First name: Heath
Last Name: Blair
City: Visalia
Have you already started work on the neck? If not, you could always use another wood such as Peruvian walnut. I've found pieces that greatly resemble the tones in EIR. I think it would look nice. I, too, like the stained look in the example above. Good luck!
sweat the small stuff.
PostPosted: Sat May 23, 2015 12:43 pm
That looks fantastic! Thanks for allowing me to see this stain in action. What is the base of the stain, oil, water? Did you thin it? If so to what viscosity?
-j
I have started the neck and I like the idea of trying the Peruvian but I've already got this neck in my hands and don't wanna wait any longer. There's been so much waiting on parts and tools I'm at the point where I'm just sick of it. Also, the piece of Mohagany I have is spectacular! Kind of nervous using it on a first guitar but I made a practice neck and it turned out great so it shouldn't be a problem.
I did make some stain from scratch using rosewood. I'm gonna give it a shot. I'm experimenting with the raw, squared wood, I assume this is the best way, no? Then "attempts" can be planed off during the thicknessing stage and I'll know what works. I can try all the suggestions here in the process.
-j
PostPosted: Sun May 24, 2015 6:14 am
Last Name: Howard
City: Magnolia
State: Delaware
Solar-lux is a dye stain in a type of glycol base. I did not thin it with anything but they have a reducer for it to lessen color intensity when needed. if just using as a stain you can cut it with DA for the same effect. Being glycol based means that it is compatible as a dye additive for both solvent and water borne finishes which is another reason i like it.
Sometimes when trying to stain to a darker color with modern oil or WB stains the pigment tends to lay more on the wood instead of penetrating and can cause adhesion problems.
Brian
PostPosted: Sun May 24, 2015 7:35 am
Practice your stains and finishing experiments on scrap wood, not the actual neck. Also, home made stains are usually not very long lasting. Buy a can, especially if you are getting anxious to get this one done.
PostPosted: Sun May 24, 2015 8:38 am
Mohawk's Ultra penetrating stain is a dye stain that can be used directly on the wood and/or mixed with many different finish materials (as a toner - nitro, shellac, and some waterbournes - test for compatibility) It can be thinned with most solvents (including water) to adjust the strength.
PostPosted: Sun May 24, 2015 9:41 am
First name: George
City: Seattle
Pretty much every mistake I've made building a guitar has been the result of impatience. Now that I think about it, that may be true in other areas of my life as well. :-)
George :-)
PostPosted: Wed May 27, 2015 2:47 pm
Last Name: Keith
I took advice from Laurent Brondel and used a two step process. After filling the pores and sanding back to bare wood, I used Stew-Mac's ColorTone stain #5032 (Red Mahogany) dissolved in alcohol to a medium red color. On top of that I wiped MinWax #224 (Special Walnut). I tried the Minwax's Jacobean, but it was a bit too dark for this particular piece of EIR. I think it's important to practice on scrap mahogany to best match the piece of EIR at hand.
PostPosted: Thu May 28, 2015 11:01 am
I use LMI's aniline dyes, brown, red and black. After staining, I do a wash coat of shellac before filling with dark walnut. Keeps the pores a bit more crisp, keeping the color of the filler in the pores.
Mostly I don't worry about it, unless the customer wants a match.
This is my first build, 2005. It's a bit too red, but I was happy with it at the time.
Users browsing this forum: rbuddy and 260 guests
