It is currently Sun Jul 20, 2025 4:44 am
PostPosted: Thu May 01, 2014 8:40 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I would like to build a proper buffing machine (rather than pay Stewmac more than 500 dollars + expensive international shipping) but the problem is, where do I find the long shaft with threaded end?
Typhoon Guitars
PostPosted: Thu May 01, 2014 8:54 pm
First name: Rusty
You should look in a bearing supply house then take the shaft to a machine shop for the right and left hand threads.
Sent from my iPhone using Tapatalk 2
PostPosted: Thu May 01, 2014 9:08 pm
Last Name: Ensor
City: Springfield
State: Missouri
I bought a long piece of cold rolled steel rod from a local supplier and then had a machinist put the threads on the ends for me- one left hand and one right hand.
http://elevatelutherie.com
http://ensorguitars.com
PostPosted: Fri May 02, 2014 12:29 am
First name: Jeff
Last Name: Crisp
State: Victoria
Or you might find something prefabricated with thread on one end and get used to changing mops.
PostPosted: Fri May 02, 2014 8:08 am
Go kart axle.
PostPosted: Fri May 02, 2014 9:12 am
First name: anthony
Last Name: wickman
City: tallahassee
State: florida
Zip/Postal Code: 32301
I used a go cart axle. I works very well.
PostPosted: Fri May 02, 2014 9:20 am
I just bought a fully threaded rod at hardware store. nuts and lock washers on both sides of buffing wheels. no problem so far and I have done a lot of buffing. by the way, the rod was 3/4 inch. 1 inch would probably be better.
Under Compensated Nut!
PostPosted: Fri May 02, 2014 9:29 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I was wondering about using a threaded rod, how well does it work? I'm not sure having it machined by a machinist is cheaper than buying it from Stewmac.
Typhoon Guitars
PostPosted: Fri May 02, 2014 10:09 am
It works fine. Pretty much the same as one you'd buy. Maybe doesn't look as pretty, but nevertheless, does the job well.
Sent from my GT-P3113 using Tapatalk
