It is currently Sat May 03, 2025 3:55 pm
PostPosted: Mon Apr 22, 2013 9:35 pm
Last Name: Sollod
Does anyone make a 1/4" pattern cutting bit? 1/2" are easy to find, but I'd like a smaller diameter like 1/4". ...Like a flush cut but with the bearing on the other end. I can't seem to find one...
www.swiftcreekguitars.com
PostPosted: Mon Apr 22, 2013 9:51 pm
First name: Doug
Last Name: Balzer
City: Calgary
State: Alberta
Lee Valley
Doug
PostPosted: Tue Apr 23, 2013 9:42 am
Last Name: Sollod
Nice guess Doug, but I didn't see one on the Lee Valley website (unless I missed it...). I found a way to use my 1/4" flush cutting bit for my immediate need, but I'd sure like to find a 1/4" pattern cutting bit...
PostPosted: Tue Apr 23, 2013 11:45 am
First name: Mark
Last Name: Warner
Smallest I've seen is the 3/8" bit at stewmac, and Amana makes a similar one.
PostPosted: Tue Apr 23, 2013 2:10 pm
First name: Doug
Last Name: Balzer
City: Calgary
State: Alberta
Not a guess.
http://www.leevalley.com/en/Wood/page.aspx?p=51851&cat=1,46168,69435,46171&ap=1
Doug
PostPosted: Tue Apr 23, 2013 3:15 pm
Last Name: Sollod
That'll work. I didn't see it when I looked before. Thanks Doug. I'd prefer one without the bearing on the bottom for some applications, but this one will work for others. I just cut out an f-hole using my 1/4" flush cut bit, but I had to go at it from the back of the top (not attached yet). Would have liked to go at it from the front...
PostPosted: Tue Apr 23, 2013 3:31 pm
First name: Mark
City: Concord
Whiteside has a spiral flush cut bit in a 1/4" diameter cut and a bearing on the end. RFT2100 (up cut) RFTD2100 (down cut).
 Post subject: Re: 1/4
PostPosted: Tue Apr 23, 2013 5:32 pm
First name: Dan
Last Name: Miller
City: Cape Vincent
Zip/Postal Code: 13618
Doug Balzer wrote:
I do believe that while it is 1/4" shank, it is 1/2" or 3/4" cutter diameter...
PostPosted: Tue Apr 23, 2013 10:40 pm
Last Name: coloccia
Country: States
Exactly what I came here to post. I just bought one to route a pickguard for an archtop with tight curves. Cool design. The bearing is pressed on. Your local Woodcraft will probably have it in stock.
PostPosted: Wed Apr 24, 2013 8:39 am
Dan Miller wrote:
That's also my understanding of the specs...
Alain Moisan
(Now building just for fun!)
PostPosted: Wed Apr 24, 2013 6:12 pm
I've got a 1/4" pattern bit with the bearing on the end (only way they will work of course) that I got at Woodworker's Source. Great for cutting pickguards to match neck pockets on electrics and stuff.
PostPosted: Thu Apr 25, 2013 9:28 am
First name: John "jd"
City: Santa Barbara
Steve,
What you are looking for sounds like a scary bit. 1/4" shank bits are not very stiff to begin with, relieving the shank to add the bearing would make it much worse. Adding the mass of the cutter below the relieved shank is a good recipie for vibration and failure -and that is assuming you can figure out how to manufacture a bit with the cutter and shank having the same OD while somehow fitting a bearing with the same OD between them (2 piece shank?)
You can top pattern cut with a standard 1/4 spiral bit, just be sure you have a hard surface on the template and guide using the shank of the bit.
-jd
PostPosted: Thu Apr 25, 2013 10:38 am
Not gonna find it. JD makes good points.
Try a regular 1/4" bit & a collar (adjust pattern accordingly) or pin router.
Milton, ON
PostPosted: Thu Apr 25, 2013 11:23 am
Last Name: Sollod
Dave,
I had a feeling I wasn't going to find it, but you and JD have good points.
Thanks Guys.
PostPosted: Thu Apr 25, 2013 3:05 pm
Last Name: coloccia
Country: States
Uhm, not to belabor a point, but Whiteside makes such a bit, we gave you the part number for it, both up spiral and down spiral, and I have one that I use....and it works perfectly well. I'll even give you a link to where you can buy it.
http://www.woodcraft.com/product/200800 ... -3-ol.aspx
or if you want down spiral
I even took the liberty of checking stock online at the Raleigh Woodcraft, and they have both bits in stock. You can go there right now and buy one
gaah
LOL. Took me a while to find them the first time too, and as far as I know Whiteside is the only one that makes such a bit. Now excuse me while I go run around outside. We're finally getting some nice weather here
bliss
PostPosted: Thu Apr 25, 2013 6:44 pm
City: Santa Barbara
gaah
bliss
John, flush trim bits exist and the Whiteside ones you linked are very good -this is a normal application for laminate trimmers.
I believe Steve is looking for a pattern trimming bit which has the bearing located between the cutter and the collet.
-jd
PostPosted: Thu Apr 25, 2013 10:51 pm
Last Name: coloccia
Country: States
gaah
bliss
-jd
Well in that case never mind. [headinwall]
Now if you'll parden me, I think I'll go enjoy this beautiful spring evening and full moon by running around a bit more outside.
bliss
PostPosted: Fri Apr 26, 2013 1:36 pm
Nope. Smallest you'll find are 3/8" bits w/1/4" shank. I roll my own w/ 3/8"straight bits, and tubes of 1/4-3/8 bearings from ebay or a hobbyshop. I very strongly suggest using 2 bearings.
MLCS also has spiral flushtrims:http://www.mlcswoodworking.com/shopsite_sc/store/html/smarthtml/pages/bt_solid.html#spiral_flushtrim_anchor
https://soundcloud.com/jeffreylsuits/he ... -runnin-13
PostPosted: Sun Apr 28, 2013 8:10 pm
First name: James
State: Maine
I searched a lot a few years back for a 1/4" pattern bit. Came to the conclusion that they don't exist. (If they do exist, as a few have said they have one - that would be awesome if someone would point out a link to where one can be found online.) Even 3/8" is rare. Like others have said, stew mac has one of those.
PostPosted: Mon Mar 17, 2014 7:34 am
First name: Alex
Last Name: Mendoza
City: qc
Zip/Postal Code: 1108
Country: philippines
Can i get a free unit if i direct you to where you can purchase one?
you guys could share and buy me a 1/4 template bit for helping you guys out LOL
amana Makes them, i asked a relative of mine to buy me one before, im sure it would be easier for you guys to obtain it, people from US and Europe :)
here you go chaps
http://www.amanatool.com/bits-fv/mini_b ... -bits.html
or you can get them here
http://www.toolstoday.com/p-6238-miniat ... guide.aspx
if thAT doesnt work im sure you can get them here
http://www.amazon.com/Flush-Plunge-Temp ... B00DWV86J6
Cheers and i hope i help direct you guys out, not bad for my 1st post been registered before but never got to post anything
PostPosted: Mon Mar 17, 2014 8:52 am
Well, I'll be..... well done Alex... learn something every day! :)
Milton, ON
PostPosted: Tue Mar 18, 2014 2:32 am
Last Name: Shaw
City: Philadelphia
State: PA
Zip/Postal Code: 19125
MLCS
http://www.mlcswoodworking.com/shopsite ... flush.html
Another day, another dollar.
PostPosted: Tue Mar 18, 2014 7:27 pm
City: Santa Barbara
be sure to read the note on the bottom of Amana's web page on these bits
"*Reduce RPM & Feed Rates (IPM) by 30-50% to prevent tool breakage due to extremely small diameter (D). Bits are not guaranteed due to extremely small diameter."
PostPosted: Tue Mar 18, 2014 7:50 pm
Last Name: Parchem
City: Seattle
State: Wa
Zip/Postal Code: 98177
Does anyone use the 1/4 inch shaft of a 1/4 inch end mill or a 1/4 spiral flush cut bit. I usually use pattern Barings in my router with a oversized template to match. I did use the shaft to clean out head stock slot once with success.
PostPosted: Thu Mar 20, 2014 3:21 am
First name: Alex
Last Name: Mendoza
City: qc
i do that when i cut my f-holes, nothing wring with it you need a thicker template so you dont cut something too deep
