It is currently Sun Apr 26, 2026 1:35 pm
PostPosted: Fri Jul 12, 2013 12:58 pm
Any tips for measuring tool diameters? Calipers will work "OK" on 2&4-flute cutters but not on odd number ones.
Also any tips for managing the diameters? I've been in the habit of setting up my tools at "spec" diameter in VisualMill not measured diameter.
I haven't looked into cutter comp on the machine yet. Now I've got an expensive bit back from sharpening and it will be a smaller diameter which will cause problems with neck pocket fit if I don't correct it.
PostPosted: Fri Jul 12, 2013 2:27 pm
Get a real micrometer. Calipers can be forced into slightly wrong measurements.
PostPosted: Fri Jul 12, 2013 5:35 pm
This may seem dumb but, setup a drill pattern in say mdf or hard plastic and drill a few holes and measure them all , take the median diameter. Should get you close enough and will include any runout measured as well. Set your plunge rate low to eliminate flex at contact. One more thing if you have any elongation in the holes then your Z axis is not square to either X or Y or both depending on where the elongation occurs in relation to those axis.
Just a dumb thought. LOL!!!
MK
I'm outside looking in, just farther from the window than most.
PostPosted: Fri Jul 12, 2013 8:04 pm
Thanks Chris.
Mike, I think you're right. The best way to measure an odd flute bit would be to mill a slot and measure that.
Thanks guys.
Probably.
Last edited by Sheldon Dingwall on Fri Jul 12, 2013 11:38 pm, edited 1 time in total.
PostPosted: Fri Jul 12, 2013 8:16 pm
First name: Jeff
Last Name: Scott
City: Duncan
State: B.C.
Zip/Postal Code: V9A 6L7
I mill a slot in scrap and measure the width of the cut.
Jeff Scott
PostPosted: Sun Jul 14, 2013 11:08 pm
First name: Nelson
Last Name: Palen
A drill index would get you close if the tool being measured is in the size range of the index.
PostPosted: Mon Jul 15, 2013 11:56 am
-measure:
for even flute numbers
for odd flute numbers
or cut a slot.
-use your cutter comp.
PostPosted: Sat Jul 20, 2013 12:58 am
Last Name: Garrish
If you have plug gages the right size, or know how to use a telescoping gauge properly, then drilling holes is the way to go.
If not: machine a boss by taking two passes some set distance apart, then measure the width of what's left. Slots are harder to measure accurately, and if you can then you've got the tools to use the drilling method.
Bob Garrish
