It is currently Sat Jul 26, 2025 6:46 am
 Post subject: Cam clamp coming loose
PostPosted: Mon Apr 29, 2013 9:26 am
First name: Enrico
City: Rome
Country: Italy
Hi guys,
let's see if someone had the same problem. I clamp the soudnboard on my MDF solera with cam clamps. Some of them just release. No matter how hard I tighten, sooner or later they just release. Not all of them. I really can't understand why this is happening.
PostPosted: Mon Apr 29, 2013 10:05 am
Yeah I have that problem too with two of my clamps. They can probably be fixed some how.
PostPosted: Mon Apr 29, 2013 10:16 am
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
Protective cork pads on a clamp could be the problem. When you tighten the clamp, the pad compresses, but after a while the compression dissipates laterally. The same thing can happen with a circular screw clamp on a rubber hose. Over tightening the clamp makes it worst. Just snug the clamp enough to do the job.
Alex
PostPosted: Mon Apr 29, 2013 12:29 pm
First name: Caspar
Last Name: Cohu
City: Co. Cork
Country: Ireland
This has happened to some of my clamps where the steel bar had worn smooth from repeated use on the same spot and so there wasn't enough friction to stop the cam portion from sliding. I cut a few little notches with a hack saw to leave a rough surface on the bar and they work fine again now.
PostPosted: Mon Apr 29, 2013 1:56 pm
First name: George
City: Seattle
Happens to me as well. The bars on my clamps are not worn, so, in my case, I think it's what Alex is describing.
George :-)
PostPosted: Mon Apr 29, 2013 2:18 pm
First name: Enrico
City: Rome
Country: Italy
I see... so it's relatively common. I am surprised since I did not make much use of them as I am an amateur. I'll see if Incan fix them.
PostPosted: Thu May 02, 2013 7:25 am
What brand of clamps are they Enrico, or did you make them?
PostPosted: Thu May 02, 2013 4:05 pm
First name: Enrico
City: Rome
Country: Italy
They are klemmsia. The standard cam clamps in every luthier's workshop. The bar has always been smooth and cork is ok. So I guess its just broken.
Users browsing this forum: doncaparker and 21 guests
