It is currently Wed Apr 22, 2026 4:06 pm
 Post subject: Bridge mistake
PostPosted: Sat Mar 02, 2013 8:26 pm
First name: Beth
Last Name: Mayer
City: Tucson
State: AZ
So I got ahead of myself and glued the bridge on a uke project before drilling the holes for strings. I've attached a couple pics.
The options I'm considering are making it a pin bridge.... If so, do I need to thin the pin area before drilling and countersinking? I'm not sure I can get a decent break angle over the saddle if I just drill it as is. Second option might be to just drill 1/16" holes where pins would go, and basically have the strings go through the bridge/top/bridge plate the same way a pin would...I guess it would be a pinless bridge. Finally, if there were a way to clear the lower 4" of body, I could still place the string holes as originally intended, like a classical tie-block.
Thanks for the help!
 Post subject: Re: Bridge mistake
PostPosted: Sat Mar 02, 2013 8:54 pm
First name: Trevor
Last Name: Gore
City: Sydney
You could try one of these methods.
http://www.goreguitars.com.au
PostPosted: Sat Mar 02, 2013 8:59 pm
You can get extra long drill bits down to 1/16".
http://www.amazon.com/gp/aw/s/ref=sr_rd ... 11&ie=UTF8
PostPosted: Sat Mar 02, 2013 10:01 pm
First name: Big
Last Name: Jim
do you have a dremmel ? Mine has a flexable attachment that you can mount a drill bit in and drill those with no problem i bet .
PostPosted: Sat Mar 02, 2013 10:02 pm
First name: Big
Last Name: Jim
Available 8" in lengthI believe
PostPosted: Sat Mar 02, 2013 11:20 pm
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
Beth - please don't smash it in the mouth ala Tony! wow7-eyes oops_sign wow7-eyes
Alex
PostPosted: Sun Mar 03, 2013 1:02 am
First name: Beth
Last Name: Mayer
City: Tucson
State: AZ
Those long bits will work. Wud, I did try the flex shaft on my Dremel outfit and the handle is too large without a long bit.
Thanks for all the suggestions, guys.
PostPosted: Sun Mar 03, 2013 11:29 am
First name: Beth
Last Name: Mayer
City: Tucson
State: AZ
Todd, that is exactly what I will do. I was worried about stiffness and accuracy with a long bit.
.25" ID tubing seems small to accept the shank, but it obviously worked for you. Thanks for another great mini-tut. I appreciate the time everyone took to read and respond!
PostPosted: Sun Mar 03, 2013 12:11 pm
First name: Big
Last Name: Jim
Sweet Idea Todd .. Include that Tut in the Jigs subforum , Im sure many will try it as well . [:Y:] [:Y:]
PostPosted: Sun Mar 03, 2013 2:11 pm
Cool Todd, great idea.
PostPosted: Sun Mar 03, 2013 11:53 pm
First name: Beth
Last Name: Mayer
City: Tucson
State: AZ
Todd's jig worked like a charm! The only part that wasn't smooth was when I superglued my finger to the apparatus. Luckily, I keep a big can of acetone in the shop (not my first rodeo).
I now have string holes in the bridge...thanks again, Todd!
PostPosted: Mon Mar 04, 2013 12:46 am
Sweet!
PostPosted: Mon Mar 04, 2013 9:46 am
First name: Tony
Last Name: C
City: Brooklyn
Shoulda punched it.
http://www.CostaGuitars.com
PMoMC
Users browsing this forum: DennisK and 20 guests
