It is currently Mon Jul 21, 2025 1:26 am
PostPosted: Tue Apr 03, 2012 7:34 pm
First name: Lars
Last Name: Stahl
City: Stockholm
Country: Sweden
Does anyone know if compensation is already calculated into the frefind 2-d calculator ?? or do I simply print the copy of the scale and later simply ad compensation as usual ??? (for the Baritone FanFret that I am building.
Lars.
PostPosted: Wed Apr 04, 2012 4:23 am
You could compare it to the Stew Mac calculator.
Mike Lindstrom
PostPosted: Wed Apr 04, 2012 6:40 am
First name: Derek
Last Name: Gibson
City: Galloway
Country: Scotland
I have the same question on a parlour fanfret build, further complicated as I cant remember the exact scale lengths I used oops_sign
I was planning on using the printout to locate the front edge of the saddle and then compensate from there.
Also I was going to use the printout to locate the bridge pin holes - does anyone see a problem with this?
PostPosted: Wed Apr 04, 2012 10:49 am
Last Name: Renick
City: Mount Shasta
State: ca
Zip/Postal Code: 96067
Country: us
Compensation is not built into that program. I did use it for 2 fan fretted guits, glued it to the fretboard, cut by hand, compensated off the E strings' path.
http://shastaguitar.com/
http://www.kalimbakit.com/
PostPosted: Wed Apr 04, 2012 3:21 pm
First name: Lars
Last Name: Stahl
City: Stockholm
Country: Sweden
Thanks comfyfoot... So what your saying is to just ad on the high and low E as normal. [:Y:] .
Mike, Stewmacs cant be used for FanFrets. but if you meen to just ad what that scale will give me as compensation to both scales, i am with you [:Y:]
Derek, just measure half distance as usual on both sides and you will get what scale you were using. ( double the lenghts on each side and you will see how and where to put the bridge etc..) or did i misunderstand you. ? (if so I can always blame it on that I have blond hair and from Sweden laughing6-hehe ..
lars
PostPosted: Wed Apr 04, 2012 3:56 pm
First name: Derek
Last Name: Gibson
City: Galloway
Country: Scotland
I'm a blond Irishman! laughing6-hehe
Thanks Lars, i have done that but was concerned about accuracy I suppose. Can you tell me what your spacing for the bridge pins is as I have got myself confused in that if the bridge is skewed as on a fan fret won't that mean a slight closing of the string spacing if I use a normal bridge template?
PostPosted: Thu Apr 05, 2012 10:04 am
You need to lay out the string pin holes on the angle of the saddle ... a littel trig will tell you what the actual spacing between the pins (or the total spread, then divide by 5) is for the angle of the saddle you are using
The spacing of the pins will be wider, but once you angle the bridge, the actual string spacing as it goes towards the neck is whatever spacing you wanted it to be .. draw it out ... for instance if you have 2 3/16 string spacing, then as the saddle angles more, and assuming your pins are parallel to the saddle slot, then the space between pins gets wider
