It is currently Sun May 03, 2026 6:01 pm
PostPosted: Sun Feb 05, 2012 4:48 pm
First name: Darryl
Last Name: Young
State: AR
Do you typically lower the height of the X brace intersection for smaller body guitars? When I was building my 000, I think folks here suggested using about 0.600" so I'm wondering if you use less for a 00 body. I think Martin uses 0.625" but I'm unsure if that height is needed on such a small body. Ultimately, I'll use the frequency of monopole mode to decide if I want to lower the height at the intersection.......just curious where you guys start.
PostPosted: Sun Feb 05, 2012 5:06 pm
I lower mine on the smaller guitars. They are also thinner. How wide is the brace in question?
PostPosted: Sun Feb 05, 2012 5:44 pm
First name: Darryl
Last Name: Young
State: AR
Good point Mark, I should have mentioned that. My bracing is 1/4" wide and currently about 0.620" height at the X-brace intersection. I need to cap the X-brace and if the concensus is that I likely need to lower that height, I go ahead and lower it some before capping the first time. If I need to go lower later, I'll have to cut off the cap, sand lower, and re-cap.......so getting fairly close from the start might save a few iterations of this.
PostPosted: Sun Feb 05, 2012 5:49 pm
I am usually only a bit over 1/2" on my OO sized guitars. I do deflection test all my braces, so I know they are as stiff as the last time I went that short. I am also using .3 wide braces, pretty much on everything.
Burton
Brookline, MA.
PostPosted: Sun Feb 05, 2012 6:00 pm
I always cap my x-braces, but i don't take into account the final height at the cap as much as the oveall brace height. I don't feel it would make much difference in sound one way or the other as the cap area isn't in a place to effect that very much.My guitars on that size have a 1/4"x 5/8" brace to start out when glued down and my cap adds 1/16" to that at the x intersection. That's with sitka spruce braces. I don't worry about frequencies. I carve and tap tune over my braces until i'm satisfyed that i'm getting a good clear tone over them as well as the bridge plate area. That's just how i do my voiceing.
PostPosted: Sun Feb 05, 2012 6:27 pm
Last Name: Arnold
City: Newport
Zip/Postal Code: 37821
On the 1930's Martin 00's, the X-braces typically measure 0.265" wide by 0.535" tall.
PostPosted: Sun Feb 05, 2012 7:23 pm
First name: Darryl
Last Name: Young
State: AR
John, that's great information, thanks! Do you know what X-Brace angle was used on those '30s Martin 00s? I'm building a Norman Blake style 00 and it has a 95 deg angle.
PostPosted: Sun Feb 05, 2012 7:26 pm
First name: Darryl
Last Name: Young
State: AR
Mark, I'm not including the cap in the height measurement.
PostPosted: Sun Feb 05, 2012 7:30 pm
First name: Darryl
Last Name: Young
State: AR
John, on those old '30s Martins, any chance you know the distance from the X-Brace to the first peak on the upper tone bar?
PostPosted: Sun Feb 05, 2012 7:58 pm
State: Tennessee
I have a John Arnold supplied tracing of a 1938 OO (14 fret).
It has 93 degrees for the angle and its 3 inches on the base side to the first peak.
The treble look about 3-1/16
PostPosted: Sun Feb 05, 2012 8:52 pm
First name: Darryl
Last Name: Young
State: AR
Clinchriver, I wasn't very clear but I was askinga for a measurement on the tone bar.......from the X-Brace to the first peak. Any chance you have that measurement?
PostPosted: Sun Feb 05, 2012 8:54 pm
First name: Darryl
Last Name: Young
State: AR
Thanks Burton, Mark, and Todd!
PostPosted: Sun Feb 05, 2012 9:04 pm
State: Tennessee
No problem.
Top tone bar, 2-1/16 inches, Bottom, 2 inches
PostPosted: Sun Feb 05, 2012 9:27 pm
First name: Darryl
Last Name: Young
State: AR
Thanks CR!
PostPosted: Sun Feb 05, 2012 10:21 pm
First name: Francis
Last Name: Richer
City: Montréal
State: Québec
Zip/Postal Code: H4G 2Z2
I'd say 1/2 to 9/16
Francis Richer, Montréal
Les Guitares F&M Guitars
PostPosted: Sun Feb 05, 2012 10:37 pm
Last Name: Arnold
City: Newport
I would not rely on the bracing locations of a 14-fret Martin to build a Norman Blake style guitar, since the bridge is in a different place.
I would start with the X-bracing spread at the bridge and work out the rest based on that.
My preference is to have the X-braces intersect the back corners of the bridge, but YMMV.
PostPosted: Mon Feb 06, 2012 3:16 pm
First name: Darryl
Last Name: Young
State: AR
I'm not John, so no worries there. I do want to know some of these measurements on a standard 00 to see how much I vary. I have the X brace laid out as Todd descibes and just like on the NB 000. I'm using a single tone bar and single finger braces.
Users browsing this forum: Ken Lewis and 110 guests
