It is currently Sun May 10, 2026 7:00 am
 Post subject: padauk end checking
PostPosted: Sun Jan 15, 2012 2:38 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I think the Padauk I got wasn't completely dried, so when I placed the billet in the dry room the end checked.
Is this a lost cause, or can I simply CA the crack shut as soon as I resaw it?
I don't have enough space to cut it off, because I also want to get ukelele sides out of it.
Typhoon Guitars
 Post subject: Re: padauk end checking
PostPosted: Mon Jan 16, 2012 2:23 am
Last Name: Shaw
City: Philadelphia
State: PA
Zip/Postal Code: 19125
Even when dry it has a tendencies to check. When i used it I had enough to just cut them out. I think CA would work the way you want it to. By the way it is very hard to bend. It can crack easily. Soaking in hot water helps and so does slow easy bending....Mike
Another day, another dollar.
PostPosted: Mon Jan 16, 2012 6:46 am
First name: Kevin
Last Name: Looker
City: Worthington
State: OH
Zip/Postal Code: 43085
The stuff is pretty brittle & will easily split. Be careful with the ends. After thicknessing I put masking tape along the ends.
I've only bent one set & it was very easy to bend although I know many have had trouble. The set I had was perfectly quartered which may have made the difference.
Kevin Looker
I'm not a luthier.
PostPosted: Mon Jan 16, 2012 9:11 am
You can ca it after you resaw it to keep it from cracking futher. It will like to crack as drying when thick, so you might want to resaw i as soon as possible to keep the cracking to a minimum. It does like to crack. I just bent a set for a dread without any problems but it was from a dry well quartersawn billet to start with. The problem i'm worried about is the red dust impregnateing the light colored binding i want to put on it. gaah
PostPosted: Mon Jan 16, 2012 9:30 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I took it out of the dry room and as soon as its exposed to the higher RH outside the check started closing
Typhoon Guitars
PostPosted: Mon Jan 16, 2012 7:43 pm
First name: Patrick
Last Name: Hanna
State: Missouri
It looks closed, but it probably won't stay closed. The cracks are still present. Ergo, heed Mark Groza's advice. You'll be glad you did.
PostPosted: Tue Jan 17, 2012 1:17 am
Last Name: Shaw
City: Philadelphia
State: PA
I also want to mention that sometimes there can be difficulty gluing up. Titebond works well but glue up within about an hour of jointing the edges, Waiting longer can cause problems. I think it is an oil issue or oxidation? Not really sure. Now the stuff I used was African Padauk. There is also an Asian Padauk and I don't know if they have the same issues....Mike
PostPosted: Tue Jan 17, 2012 11:16 am
I would skip the ukulele sets and just build with good solid wood. Enough problems come along that you don't need to start with a problem that you know you have. I doubt that the wood is that expensive. It's one of the least expensive back and side woods at LMI.
+1 for resawing soon.
Ken Franklin
clumsy yet persistent
PostPosted: Tue Jan 17, 2012 12:55 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I can't do that, this is a part of the OLF challenge, ordering from LMI would disqualify me.
I believe the wood is Burmese Padauk.
Also the resawn set did not exhibit checking, and there are enough wood for me to cut off the checked portion if necessary.
Typhoon Guitars
Users browsing this forum: Cal Maier and 60 guests
