It is currently Sat Aug 16, 2025 6:08 pm
 Post subject: Glove liners
PostPosted: Tue Jan 03, 2012 8:41 pm
First name: Wendy
Last Name: W
State: Arizona
In another post Waddy mentioned wearing glove liners under his nitrile gloves when French polishing. Waddy, if you're out there, or anyone else who knows...where do you get them and do they come in different sizes? Thanks, Wendy
 Post subject: Re: Glove liners
PostPosted: Tue Jan 03, 2012 9:22 pm
Yes, different sizes and different thicknesses. Problem is you have to buy a dozen. However, they are not expensive < $7.00/doz. I got mine from Northern Safety, on line.
Light Weight - http://www.northernsafety.com/Product/1 ... e=CFSA0911
Medium Weight - http://www.northernsafety.com/Product/1 ... e=CFSA0911
PostPosted: Wed Jan 04, 2012 11:05 am
Why do you wear liners?
PostPosted: Wed Jan 04, 2012 11:06 am
First name: Wendy
Last Name: W
State: Arizona
Wow, that was fast, thanks Waddy. Even those lighter ones look pretty thick in the picture. I would assume you have to use a larger size nitrile glove to fit over it. The ones I wear now are a size small, and they are actually a little tight.
PostPosted: Wed Jan 04, 2012 11:08 am
First name: Wendy
Last Name: W
State: Arizona
The reason for the liners, according to Waddy's post that I read, is that it helps with the sweating inside the nitrile gloves.
PostPosted: Wed Jan 04, 2012 11:47 am
My hands sweat a lot when wearing nitrile gloves, so the liners sound interesting. The ones linked above are cotton, which is not very effective at wicking moisture away from the skin. There are light weight glove liners available for skiing and other outdoor activities made with materials much better at wicking moisture, but the ones I'm aware of are more expensive. Anyone know of a source for "disposable" wicking liners?
PostPosted: Wed Jan 04, 2012 1:52 pm
Oh ok I understand. Yeah mine get sweaty too but then I didn't wear gloves when I French Polish. Maybe I should.
PostPosted: Wed Jan 04, 2012 5:09 pm
First name: Wendy
Last Name: W
State: Arizona
The only reason I wear gloves when French polishing is because without them I end up putting a good long scratch in the finish with my fingernail. That hasn't happened with gloves on...yet.
PostPosted: Wed Jan 04, 2012 5:34 pm
My reasons are for both. I'm a player, so I have player's nails = longer than normal. It's easy to screw up a perfectly nice looking FP'd top with one stroke. Then you have to steam it out and pretty much start over, unless you are keeping it yourself. The sweaty hands thing is also nice. They do help with that too. Pretty hard to wick sweat away inside a rubber glove! You just need something to absorb some of it. Cotton is perfectly good for that.
cron
