It is currently Tue Jul 22, 2025 8:37 am
 Post subject: General Finishes
PostPosted: Wed Sep 28, 2011 7:39 am
Anybody tried General Finishes on steel strings? Either the Enduro-Var, Pre-cat urethane and Clear poly? And what were your results?
http://www.generalfinishes.com/professional-products/water-base-topcoats-and-sanding-sealers
Laurent Brondel
West Paris, Maine - USA
 Post subject: Re: General Finishes
PostPosted: Wed Sep 28, 2011 8:16 pm
Sorry Laurent I have nothing to offer but thought I would give this a bump.
Link
PostPosted: Wed Sep 28, 2011 8:47 pm
First name: Kenneth
Last Name: Casper
City: Northville
Country: U.S.A
I have used their wipe on finishes for years, but never on a guitar.
Ken
http://www.casperguitar.com
PostPosted: Thu Sep 29, 2011 8:10 am
As it happens, I just received a quart of Enduro-Var in the mail yesterday. I hope to spray a test panel in the next couple of weeks. Here is some info that I received from General Finishes to my questions about Enduro Var and the Pre Cat Urethane.
Quote:
Brook use the Enduro Var. It is more like an oil urethane and can be recoated in 2 hours. This product will give you excellent depth and is extremely durable. Water base products do not have burn in like the lac but they attach on. So you are better letting it dry out for a good two hours between coats. We recommend letting it dry dry good for 2 weeks
I also have a couple guys that do this for a living and here is a suggested system they used for a project they did with our Enduro Var...
yep, he did the back to back thing, to create a uniform 1 coat for the final rub
Subject: FW: Schedule for EV
Try this schedule. It takes 3 coats 1 day and 3 coats the next day.
________________________________________
Sent: Tuesday, April 13, 2010 4:47 PM
To: 'Tom Monahan'
Subject: Schedule for EV
1. Prep wood to 220
2. Spray full wet coat of EV gloss - wait 2 hours
3. Level sand 320 - spray 2 nd full wet coat wait 2 hours - light sand 320
4. Full wet coat --- wait over night
5. Level sand with 320 - wipe with water and 5% DNA
6. Wet coat 2-3 mils dry 1 hr and repeat twice for a total of 3 coats only 1 hr in -between
Let dry 1 week
Level sand dry with P800 Mirka.
Sand dry with P1200 Mirka
Sand with 2000 grit Abralon dry
(Note - do NOT use lubricants of any type to level sand)
Then - 3M Finesse-it Finishing Material on foam buffing pad to gloss.
Have a great day!
Sheryl Monahan
General Finishes
1-800-783-6050
2462 Corporate Circle
East Troy, WI. 53120
PostPosted: Thu Sep 29, 2011 1:40 pm
Brook, keep us updated on your progress. What are you going to use for a test panel?
Laurent Brondel
PostPosted: Thu Sep 29, 2011 1:43 pm
First name: Jim
Last Name: Hansen
Excellent info! Thanks...
Also you might want to remove the email address from the post before the bots find it.
Jim Hansen
PostPosted: Thu Sep 29, 2011 6:57 pm
Laurent,
I just sprayed three steel string guitars with their Clear Gloss Poly (water based) a couple of months ago. These were student guitars, and I was looking for something that was easy, relatively glossy, and durable.
For a quick finish on a student guitar, it worked well. The guitars came out of the spray process with a semi-gloss, egg-shell finish. We pretty much just used a fine grit swirl remover, then polished them, and that gave a level of shine that was sufficient for our needs.
I did level and buff out around joined areas (neck, bridge), so that if the students wanted to level and actually buff out the whole guitar later, they could. They haven't really pursued that idea, so I'm assuming that they're pleased with them the way they are.
Overall, the finish was very easy to level and work with, but the gloss is not as good as a lacquer finish.
Hope this helps...
Ken Mitchell
Durham, NC
PostPosted: Fri Sep 30, 2011 7:49 am
What General Finishes poly did you use Ken? The PolyAcrylic, High Performance, or the Enduro?
Laurent Brondel
PostPosted: Fri Sep 30, 2011 9:36 am
First name: alan
Last Name: stassforth
City: Santa Rosa
State: ca
Zip/Postal Code: 95404
I've only used their wipe on poly on a slab git, and I like it.
I think you won't be happy with water based "blueness".
Looks okay to me on light woods,
but not dark.
I would do a comparison on scrap wood.
You are a varnish guy,
and nothing in my opinion beats varnish.
I would love to find a good water based finish though.
PostPosted: Fri Sep 30, 2011 10:13 am
Last Name: Ellis
City: Manteca
Zip/Postal Code: 95337
I sprayed my last with the pre-cat sanding sealer and the pre-cat urethane (gloss). After sufficient dry time, I power leveled with micro-mesh for ROS and got very good results. Hard, flat and glossy. I'm planning on using it until I find something easier.
I love the fact that it is water-based for the cleanup and chemicals. I still wear a spray mask, but I'm not anal about it.
PostPosted: Fri Sep 30, 2011 10:32 am
First name: Al
Last Name: Darned
Just noticed in the last Lee Valley catalogue that they're carrying this stuff now, fyi.
http://www.leevalley.com/en/wood/page.aspx?p=63849&cat=1,190,42942
If trees could scream, would we be so cavalier about cutting them down? We might, if they screamed all the time, for no good reason. - Jack Handey
PostPosted: Fri Sep 30, 2011 11:00 am
Steve_E wrote:
I sprayed my last with the pre-cat sanding sealer and the pre-cat urethane (gloss). After sufficient dry time, I power leveled with micro-mesh for ROS and got very good results. Hard, flat and glossy. I'm planning on using it until I find something easier. I love the fact that it is water-based for the cleanup and chemicals. I still wear a spray mask, but I'm not anal about it.
Steve, do you want to detail your process a bit more? How many coats, and did you measure the final film thickness? How long did you let it cure? Did you machine buff it and how's the gloss? Are you happy with the way the finish looks and feels? BTW, just because it's waterbase and much lower in VOC does not mean there are no nasty chemicals in it. I wouldn't be too cavalier with protection.
Laurent Brondel
PostPosted: Fri Sep 30, 2011 11:55 pm
First name: Kenneth
Last Name: Casper
City: Northville
Country: U.S.A
Laurent, I used their Arm R Seal wipe on varnish for years with other wood projects. Prior to getting into water based lacquer about 4 years ago, Arm R Seal was my finish of choice. I used it on breakfast tables, chests, mantle clocks, and all sorts of other furniture. I used to rub it out with rubbing oil, pumice, and rottenstone. I didn't get the high gloss I get with EM6000, but I got a great finish with minimal effort. I don't know anything about GF's other finishes, but commented only to point that I was familiar with the company and had used one of their finishes.
Ken
PostPosted: Sat Oct 01, 2011 12:16 am
Last Name: O'Melia
City: Huntsville
State: Alabama
Let's talk repairability and melt in. Anything that crosslinks means to me, low melt in, witness lines, and forget repairs. Am I wrong?
PostPosted: Sat Oct 01, 2011 7:27 pm
Laurent,
The poly that I used was the High Performance water based topcoat, in gloss finish.
Ken Mitchell
Durham, NC
Laurent,
Ken Mitchell
Durham, NC
PostPosted: Sun Oct 02, 2011 7:46 am
Thank you Ken & Ken, I am only interested in the Enduro line of products. Mike, all the issues you point to are also valid to a great extent for oil varnish. It never bothered me.
Laurent Brondel
PostPosted: Sun Oct 02, 2011 11:17 am
Last Name: O'Melia
City: Huntsville
State: Alabama
I thought that was the case. I was not challenging the finish on those merits, I was just wondering.
PostPosted: Fri Apr 06, 2012 6:44 am
I'm bumping this as I have an interest in the Enduro water based finishes ( mainly Enduro-Var or clear gloss) and wondered if anyone had further observations/feedback?
PostPosted: Fri Apr 06, 2012 10:13 am
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
I don't know if this will help, but I used the Enduro-Var for my kitchen cabinets about two weeks ago. As a comparison, I had used EM2000 on a couple of kitchens and cabinetry before, and found the Enduro to spray much better and dry harder.
The re-coat time was 5-6 hours for my conditions. I thinned about 10% with distilled water, and sprayed with a Wagner HVLP conversion gun set at 14psi at the gun. Maybe my technique is improving, but I found much less overspray compared to the EM2000. As far as cabinetry, this is going to be my finish of choice for now.
Alex
PostPosted: Fri Apr 06, 2012 11:12 am
Alan,
Try KTM-SV, a waterborne spar varnish. It's a urethane.
Users browsing this forum: Ken Lewis, Michaeldc and 24 guests
