It is currently Thu May 22, 2025 6:05 pm
 Post subject: Drum Sander Motor?
PostPosted: Fri Jul 15, 2011 9:27 pm
First name: David
Last Name: Morris
City: McKinney
Is a 1/3HP running at 1625 rpm sufficient for powering a homemade drum sander? It could actually be as low as 1/4HP, based on my research. But it's about 70% off and brand new.
Thanks in advance!
David Morris
 Post subject: Re: Drum Sander Motor?
PostPosted: Fri Jul 15, 2011 9:36 pm
Last Name: Arnold
City: Newport
Zip/Postal Code: 37821
Not unless you are only sanding narrow strips like binding.
My 16" wide Ryobi drum sander has 1 HP, and IMHO it is underpowered.
PostPosted: Fri Jul 15, 2011 9:53 pm
First name: Big
Last Name: Jim
I have a 1/2 hp motor on ebay for sale .. item # 190555241043 for 19.99 if you wanna look at it . idunno
PostPosted: Fri Jul 15, 2011 10:05 pm
First name: David
Last Name: Morris
City: McKinney
Thanks. That's what I needed to know. Jim, I'd bid on the thing, but the shipping would kill me!
David Morris
PostPosted: Fri Jul 15, 2011 10:26 pm
A drum thicknessing sander? Not even close. As John said, 1hp is underpowered.
PostPosted: Fri Jul 15, 2011 10:46 pm
First name: David
Last Name: Morris
City: McKinney
What should I look for then? A used lawnmower, perhaps?
David Morris
PostPosted: Fri Jul 15, 2011 11:15 pm
have you built the sander? Do you have 3 phase power?
You might be best off renting time on a good sander.
PostPosted: Sat Jul 16, 2011 1:05 am
First name: David
Last Name: Morris
City: McKinney
I appreciate your input, Howard. I hope you understood I was just joking around about the lawnmower. I didn't realize I'd need three-phase power to run a thicknessing sander. I haven't built anything yet, because the motor is a big question. I'm just trying to equip my shop with a couple tools I don't yet have.
Thanks again.
David Morris
PostPosted: Sat Jul 16, 2011 1:10 am
Last Name: Livermore
State: Minnesota
David,
I built mine with a 1/3 hp 1725rpm fan motor and it works just fine. 6" drum. Granted, it takes several passes to get a top or back thinned down to final thickness, but it sure beat buying a Time Saver. I think I have about $16 with the pillow blocks in materials into this thing and it works just fine.
Very similar to those home built thickness sanders seen here or in 'free plans' on the net.
I may trade out the motor for a 3/4hp, but only because I think the bigger one is overkill to turn my radius dish and I want to motorize that.
Good luck. Let me know if you need pictures or anything of the setup.
PostPosted: Sat Jul 16, 2011 1:52 am
First name: David
Last Name: Morris
City: McKinney
Dave Livermore wrote:
David,
Yeah, that's what I'm looking to do. Nothing fancy. Just something that does the job if you take your time.
EDIT: Y'know, my apologies to everyone. Dave's comment prompted me to do a search, and I found the information I needed had already been posted. I just got caught up in the moment of a quick sale. And it's funny, because just earlier today, I was thinking about how necessary patience is in building a guitar. :oops:
David Morris
PostPosted: Sat Jul 16, 2011 2:18 am
First name: Jason
Last Name: Moe
City: LaCrosse
State: WI
Zip/Postal Code: 54601
I just built a 24" (20" sanding area). I have a 1HP dual capacitor GE motor that is plenty of power.
Jason Moe
LaCrosse WI 54601
PostPosted: Sat Jul 16, 2011 4:24 am
First name: Tom
Last Name: West
State: Nova Scotia
I have a home built with a 7" drum that has a 1 hp and I thought that would be sufficent. It gets the job done but it is slow and underpowered.
Tom
PostPosted: Sat Jul 16, 2011 4:33 am
On my home built drum sander I used a 2hp ex lawnmower motor and that seems just right, I've put a link to the build photos below
http://www.luthiercom.org/phpBB3/viewto ... 115&t=1290
Formerly JJH
PostPosted: Sat Jul 16, 2011 10:37 am
First name: David
Last Name: Morris
City: McKinney
John, thanks for that link. Of all the homemade drum sanders I've seen, I think I like yours the best. Seems sturdy and practical. Was that an electric lawnmower??
David Morris
PostPosted: Sat Jul 16, 2011 10:56 am
my shopbuilt sander is a 17 inch wide 6 inch drum that runs on a 3/4 HP .... it works pretty well, but doesnt hog off a lot of material in comparison to a large commercial one .. but I bet its better than a 10-20, and its definitely better than a buddys delta 16 inch
PostPosted: Sat Jul 16, 2011 11:45 am
Couldnt resist posting pics of mine as i just finished it
no idea about HP as its so rusty but its pretty strong and with that iron pulley wheel it is a bit of beast!
It is the power unit from a kitchen extractor fan
PostPosted: Sat Jul 16, 2011 12:13 pm
I just finished rebuilding my shop built sander, it has a 4"x24" Aluminum drum and a 1hp motor.
Runs strong enough to bend the under sized 5/8 shaft I tried to use...
I just installed a 1" shaft and it's working fine.
PostPosted: Sat Jul 16, 2011 12:28 pm
Thanks again.
I didn't say you need 3 phase power to run a thicknessing sander.
PostPosted: Sat Jul 16, 2011 1:01 pm
First name: Ken
Last Name: Hageman
City: Statesville
Zip/Postal Code: 28625
I have a Kuster home built drum sander. It is approximately 24 inches wide. It has a 5hp motor that runs the sanding drum. Nice to have that much power. I believe the feed motor of the rollers is a 1/2 hp motor.
PostPosted: Sat Jul 16, 2011 8:56 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
I built mine mostly from scrap and what I had around. It has a 24 inch MDF drum. At the time, all I had was a 1/3 up motor (at least 30 years old). It works okay when you take small bites (as you should anyway). It can get bogged down a bit with wide hardwood (over 16 inches), so I take even less off per pass with backs. One day, I will upgrade the motor like I always intended, but I'm in no hurry. I don't build a lot so it works for me.
Bryan Bear PMoMC
PostPosted: Sat Jul 16, 2011 10:46 pm
First name: David
Last Name: Morris
City: McKinney
Ok, I'm thinking I might actually try to build the whole thing (or most of it) from reclaimed materials. John used a lawnmower engine. Anybody else have creative ideas?
David Morris
PostPosted: Sat Jul 16, 2011 11:58 pm
I built my sander 8 years ago. It runs off a 1hp motor. The drum is 5" dia and 24" long. I've always got 80 grit on it and I've never once stalled it. It runs 1:1 meaning the drum spins at the same rpm as the motor (at the shaft that is). I can easily take of 0.015 in a pass on EIR and much more on softwoods if I wanted. I'm sure I'd blow the breaker before I stalled the motor on it.
Actually, it's going to be for sale very soon as I just got a 16/32 performex. My sander is self feed, a heavy steel frame and works very well. No issues ever with only 1hp...
PostPosted: Sun Jul 17, 2011 5:01 pm
First name: Chuck
Last Name: Kish
City: Saratoga Springs
Zip/Postal Code: 12866
I built one once and used an old washing machine motor -- 1725 rpm, 1/3HP, I think. Used a 6" diameter, 24" long well casing for the drum. Had it "lathed" in a vocational school machine shop - they sometimes are looking for things to practice on. Was definitely underpowered but could sand slowly taking tiny cuts each pass. I then put it right behind my table saw and got a pulley and belt long enough to share the motor with the sander -- 3450rpm, 1HP. Much better. Sharing the motor was a little less convenient, but not too bad at all. May work for you. Be sure your drum is well balanced and, of course, be very careful, especially if hand feeding!
Chuck Kish
PostPosted: Sun Jul 17, 2011 7:34 pm
First name: David
Last Name: Morris
City: McKinney
Going down to the family farm tomorrow. There's a bunch of "junk" in storage there. I feel confident I'll find something to use as a motor, and who knows what else? I know there's a working evaporative cooler there. That's probably a good place to start.
David Morris
PostPosted: Wed Jul 20, 2011 12:25 pm
My 24" Woodmaster has a 5 hp main motor and separate adjustable speed feed motor.
I have stalled it before, but mostly belt slip, not the motor stopping.
Freeborn Guitars
and home of BeauGuard©
Users browsing this forum: doncaparker, Ken Lewis, Mike Thomas and 56 guests
