It is currently Sat May 23, 2026 7:40 am
PostPosted: Wed Jun 15, 2011 9:05 am
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
I was trying to get “just one more thing finished” before bed last night. I clamped my fretboard binding on the board and wicked in the CA. Since I was rushing, I hit the back with accelerator then noticed that all the cut up strips of cottage cheese container were still sitting on the bench. oops_sign Now about 10 slots on one side of the board are glued shut (some as much as ½ an inch). I’d rather not redo the binding if I don’t have to. Anyone have a good way to clean out the blind slots?
Bryan Bear PMoMC
PostPosted: Wed Jun 15, 2011 9:16 am
City: Keene
I use an exacto. if you can find the curved pointy (#28) blade it is better.
PostPosted: Wed Jun 15, 2011 9:20 am
City: Keene
http://www.xacto.com/Product/X228
PostPosted: Wed Jun 15, 2011 9:27 am
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
I did a very quick attempt to get it out with the corner of my exacto saw blade and a regular pointy exacto blade. Neither worked well because they were too thin and or the glue too hard. That curved blade is probably better, I'll get some tonight. Do you go from the side in or from the center bottom of the slot and try to pry it out as it cuts?
Bryan Bear PMoMC
PostPosted: Wed Jun 15, 2011 9:28 am
You can modify an Exacto blade so that it is curved with a chisel head the same width as your slots. Put it in an all metal handle and heat it on propane torch. Makes it pretty easy work.
Ken Franklin
clumsy yet persistent
PostPosted: Wed Jun 15, 2011 9:32 am
Remove the appropriate feeler gauge blade from a set and grind a hook in the end with the hole using a dremel sanding drum..works a treat.
PostPosted: Wed Jun 15, 2011 9:34 am
I'd try the CA solvent. Saved me once from spending my life with a workbench glued to my fingers.
Use it judiciously, though.
PostPosted: Wed Jun 15, 2011 9:40 am
I have a putty knife that is .024. Generic Rona stock. Heat with blowtorch, slip it in the slot, and your troubles just melt away. But don't inhale....
PostPosted: Wed Jun 15, 2011 9:55 am
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
Ah, a hot knife. I hadn't thought of that. Great idea. I could get the bulk out like that then scrape it clean with a sharpened hook!
Bryan Bear PMoMC
PostPosted: Wed Jun 15, 2011 10:49 am
That's a nice looking board, Kim. What is the wood?
PostPosted: Thu Jun 16, 2011 7:25 am
Steve,
The fretboard is yet another aussie acacia, 'Acacia papyrocarpa' or more commonly known as 'Western Myall'
http://www.fpc.wa.gov.au/content_migration/plantations/species/arid/western_myall.aspx
Check the details above and you will see that this plant has evolved specifically to be made into fretboards. I am not exactly sure why a plant would do such a thing or how doing so would ensure the survival of its species, but there is no doubt in my mind that this is indeed what happened and I remain truly thankful that mother nature had the foresight and consideration to leave it just sticking up out of the dirt right here in Western Australia for me, all full evolved, and ready for slicing....thanks Mum N :D
PostPosted: Thu Jun 16, 2011 8:22 am
Steve,
I can always count on you, Kim. Thanks for putting a smile on my face. Now, to the interwebs to find me some of that Darwin-approved fretboardwood. S-
Users browsing this forum: No registered users and 146 guests
