It is currently Wed Jul 23, 2025 4:33 am
PostPosted: Mon Jun 13, 2011 9:08 am
I'm building a 24" scale steel string. Do I need to adjust the saddle compensation?
If so, how do I calculate that?
Neil
PostPosted: Mon Jun 13, 2011 9:38 am
First name: Aaron
Last Name: Craig
State: Missouri
Yes, you will need to compensate. Try Stewmac's fret position calculator. It is straight forward and should get you close. Here's the link: http://www.stewmac.com/FretCalculator
Aaron
Aaron Craig
PostPosted: Mon Jun 13, 2011 10:53 am
I have some numbers on compensation for scale lengths of 24" , 25" and 25.5". I will dig them up in the shop today and post them later.
M
PostPosted: Mon Jun 13, 2011 4:33 pm
M
On my 24" scale length guitars I add 1/32" to the amount of compensation that I use on my 25.5" scale length guitars. This has worked well for me.
M
PostPosted: Mon Jun 13, 2011 5:38 pm
You add more compensation on the shorter scale guitar?
PostPosted: Mon Jun 13, 2011 8:02 pm
Yes, more compensation on shorter scales. The shorter strings sharp out more when fretted than longer strings.
M
PostPosted: Tue Jun 14, 2011 6:56 am
Hey, glad I asked. I would have thought less compensation too.
Thanks M.
PostPosted: Tue Jun 14, 2011 12:27 pm
First name: Eric
Last Name: Reid
City: Ben Lomond
Zip/Postal Code: 95005
M
That's certainly been my experience as well. The Stew Mac calculator seems to do the opposite. Any idea what's going on there?
PostPosted: Tue Jun 14, 2011 2:48 pm
Another thing that really helps with shorter scales is shortening the distance from the nut to the first fret. It helps prevent the first 2 or 3 frets from playing sharp.
I actually do this on all my guitars regardless of the scale length. I take off about .020" on scale lengths over 25" and .030 on scale lengths of 25" or less.
I also recommend tuners with at least 16:1 gear ratios on scales less than 25". 18:1 or 21:1 is better. Tuning a short string with a 12:1 tuner can be really touchy.
M
PostPosted: Wed Jun 15, 2011 2:30 am
Last Name: Kincheloe
M
+1 to a bit of shortening at the nut end. You can always add some length back by shaping the nut, but much more annoying to try to shorten it (which I think my first one, 24.75" scale, needs). On my last one (25.5") I cut it 1/16" short and added some nut compensation ramps, which seems to have helped.
It does confuse things for the measure-nut-to-12th-fret-and-multiply-by-two method of finding scale length, however.
