It is currently Sun Jul 20, 2025 5:20 am
 Post subject: Rosette Router Bits
PostPosted: Sun Sep 12, 2010 7:11 pm
Last Name: Ensor
City: Springfield
State: Missouri
What bit do you use (assuming you route your rosettes) to cut out your rosettes in your soundboards?
i.e. Do you use straight bits?
Do you use spiral bits?
If you use spiral bits, do you use downcuts or upcuts?
I am on a quest for cleaner cut rosettes. And yes, I will be using a circle cutter in combonation with my router.
http://elevatelutherie.com
http://ensorguitars.com
 Post subject: Re: Rosette Router Bits
PostPosted: Sun Sep 12, 2010 7:30 pm
First name: Woodrow
Last Name: Brackett
City: Grover
Zip/Postal Code: 28073
I use downcuts. The main thing is they need to be sharp. I do a test cut inside the soundhole before starting the rosette. If it isn't clean I change to a new bit.
PostPosted: Mon Sep 13, 2010 3:40 pm
Last Name: Collins
City: Argyle
State: New York
Zip/Postal Code: 12809
Dido on what Woody & the other Chris said.
Take your time with rose channel cutting.
If you have spare or usless wood around always try a difficult
channel there first.
The down bits help so much to prevent tearout.
Mike [:Y:]
Mike Collins
PostPosted: Mon Sep 13, 2010 6:42 pm
As a machinist I do not use a down spiral unless the hole is cleared. The chips get forced down and into your work. I use standard up cuts from BQTOOL.COM at $6.50 they are affordable. I use 3/32 bits for the rosettes.
PostPosted: Fri Sep 17, 2010 1:40 pm
Last Name: Charnock
Country: UK
Shellac the area first it worked for me.
J
PostPosted: Fri Sep 17, 2010 1:48 pm
Last Name: Ressler
City: Sandwich
State: IL
Zip/Postal Code: 60548
How many flutes?
John Ressler
PostPosted: Fri Sep 17, 2010 4:21 pm
I use 2 flutes .
PostPosted: Fri Sep 17, 2010 4:50 pm
Last Name: Collins
City: Argyle
State: New York
Metal chips & wood chips are two different things!
The downcut will leave a clean line in wood !
Mike Collins
